Modal vs. Modeless Dialogs
02:40 AM
I have a dialog class that contains a member of type AcDbVoidPtrArray*. A
pointer is passed to the dialog object during construction that points to an
external AcDbVoidPtrArray object. The dialog works fine as a Modal and the
external AcDbVoidPtrArray object retains its logical length and other
parameters. This is not the case when I change the dialog to Modeless. The
dialog creates and shows fine, but the AcDbVoidPtrArray* member (the object
pointed to I mean) does not retain its logical length and other parameters.
Again, all I have done is changed the dialog from a modal to a modeless
through the few appropriate lines of code.
Generally speaking, what are the nuances between modal and modeless dialogs?
I understand how to create, show/hide, and destroy modeless dialogs, but
there must be something else going on that I do not understand. Thank you in
advance for your enlightenment.
