Method AcPane::DisplayPopupPaneMenu() makes AutoCAD crash
I have a class MyPane deriver from AcPane. During ARX startup I add it to AutoCAD status bar. My goal is to display popup menu when I left-click on MyPane. There is an event
virtual void AcStatusBarItem::OnLButtonDown(UINT nFlags, CPoint point)
which allows me to do that.
Here is my code
void MyPane::OnLButtonDown(UINT nFlags, CPoint point)
CAcModuleResourceOverride resOverride; // I tried to define menu globally to get rid of CAcModuleResourceOverride from here. no luck
CMenu menu;
CMenu.LoadMenu(MAKEINTRESOURCE(IDM_SOME_MENU));
// no need for result right now
DisplayPopupPaneMenu(menu);
Last line makes AutoCAD crash with access violation error.
P.S. MyPane class has ACSB_POPUP style.
deepak.a.s.nadig
I am unable to recreate the crash at my end using the sample downloadable in the below link
https://adndevblog.typepad.com/autocad/2015/04/positioning-acpane-in-statusbar.html
I have made the following changes to the sample (ensure ARXDBG tool is loaded)
         1) Display the the ARXDBG_MNU_APP of the ARXDBG tool :
void CPaneItem::OnLButtonDown(UINT nFlags, CPoint point)
	CMenu menu;
	CAcModuleResourceOverride();
	if (menu.LoadMenu(ARXDBG_MNU_APP)) {
          2) Set the ACSB_POPUP style to the pane item
Image after left button click on the pane item
Thank you for your reply. I have found the reason which caused the problem.
In 'rc' file my menu was declared like this:
IDM_SOME_MENU MENU
BEGIN
    MENUITEM "Item 1",                 ID_MENU_ITEM1
    MENUITEM "Item 2",                 ID_MENU_ITEM2
    MENUITEM "Item 3",                 ID_MENU_ITEM3
END
But it should look like this:
IDM_SOME_MENU MENU
BEGIN
    POPUP "Some Menu"
    BEGIN
    END
END
With this kind of popup menu I finally could get it work properly.
