Make a sample for read dictionary error
i have make a sample for add xrecord to entity, but while i make the sample for read the xrecod, the problem stop at acutprintf, anyone can tell me where i made the mistake?
For add xrecord:
For read the xrecord, but programe stop at acutprintf:
Error information:
BerndCuder8196
First of all, please post the code as text, not as picture. In the browser you can add code with forum button: </>
With the code i can reproduce the problem.
Next is, i think AcDb::kDxfInt32 will be sb->resval.rlong
Here an example that will work, notice, BeCAD_ItextData is an custom class from my application. It also checks if there is
always an Xrecord on the entity
Sets the Xrecord:
void setItextXrecordData(AcDbText *pText, BeCAD_ItextData *pItextData)
	AcDbObjectId extDictId = pText->extensionDictionary();
	if (extDictId == NULL)
		pText->createExtensionDictionary();
	AcDbDictionary *pDictionary;
	if (acdbOpenObject(pDictionary, extDictId, AcDb::kForWrite) != Acad::eOk)
		return;
	AcDbXrecord *pXrecord = NULL;
	if (!pDictionary->has(_T("CCNC_Data")))
		pXrecord = new AcDbXrecord();
		AcDbObjectId xRecordId;
		pDictionary->setAt(_T("CCNC_Data"), pXrecord, xRecordId);
		pDictionary->close();
	else
		pDictionary->getAt(_T("CCNC_Data"), xRecordId);
		if (acdbOpenObject(pXrecord, xRecordId, AcDb::kForWrite) != Acad::eOk)
			return;
	if (pXrecord == NULL)
		return;
	struct resbuf *prbXtn;
	if (pItextData->m_drawSpaceId == AcDbObjectId::kNull)
		prbXtn = acutBuildList(
			AcDb::kDxfInt16, pItextData->m_scale,
			AcDb::kDxfInt16, pItextData->m_unit,
			AcDb::kDxfReal, pItextData->m_height,
			RTNONE);
	else
		ads_name ename;
		acdbGetAdsName(ename, pItextData->m_drawSpaceId);
			AcDb::kDxfSoftPointerId, ename,
			RTNONE);
	pXrecord->setFromRbChain(*prbXtn);
	pXrecord->close();
	ads_relrb(prbXtn);
Reads the Xrecord:
bool getItextXrecordData(AcDbText *pText, BeCAD_ItextData *pItextData)
	if (acdbOpenObject(pDictionary, extDictId, AcDb::kForRead) != Acad::eOk)
		return false;
	AcDbXrecord *pXrecord;
	if (acdbOpenObject(pXrecord, xRecordId, AcDb::kForRead) != Acad::eOk)
		return false;
	pXrecord->rbChain(&prbXtn);
	pXrecord->close();
	struct resbuf *pTemp;
	pTemp = prbXtn;
	pItextData->m_scale = pTemp->resval.rint;
	pTemp = pTemp->rbnext;
	pItextData->m_unit = pTemp->resval.rint;
	pItextData->m_height = pTemp->resval.rreal;
	if (pTemp != NULL)
		ads_name ename;
		memcpy(ename, pTemp->resval.rlname, sizeof(ads_name));
		acdbGetObjectId(pItextData->m_drawSpaceId, ename);
	else
		pItextData->m_drawSpaceId = AcDbObjectId::kNull;
	ads_relrb(prbXtn);
	return true;
thank you! very appriciate, now i found a very strange things. if i not use "sb=rb", and just "acutPrintf(_T("\n对象的属性为:%s"),rb->resval.rstring)", the program is successful, if i used the temporary resbuf "sb", the program error and stop.
Alexander.Rivilis
Delete line acutRelRb(sb) because you twice free the same memory.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Perfect! it was done like you said, thank you!
Alexander.Rivilis
I've reassign Solution as far as you mark your post, which does not contain Solution, instead of my or @BerndCuder8196 post.
Expert Elite Member
