loading the dll through arx application
waseefur.rahman
waseefur.rahman
I am trying to load the dll through arx application,
bool bLoads = acrxLoadModule(pathLvPty, true);
there are two dll which is being loaded in that one is successfully loaded, while other gives the error message as:
acrxGetApiVersion not found in e:\waseef\property_isolate.dll
Make sure the app links with rxapi.lib and export the symbol.AcRxDynamicLinker failed to load 'e:\waseef\property_isolate.dll
Can anyone please advice, where I need to change to load the dll successfully.
Alexander.Rivilis
Both dll's are arx/dbx files? If dll is mixed/managed application you have to load it such as:
1) LoadLibrary()
2) Also acdbmgd.lib export function LoadManagedDll:
enum Acad::ErrorStatus __stdcall LoadManagedDll(ACHAR const *path);
Sample:
static int ads_netload(void)
  struct resbuf *pArgs = acedGetArgs () ;
  acedRetNil();
  if (pArgs && pArgs->restype == RTSTR) {
  Acad::ErrorStatus es = LoadManagedDll(pArgs->resval.rstring);
  if (es != Acad::eOk) {
     acutPrintf(_T("\nLoadManagedDll(\"%s\")=%s"),
        pArgs->resval.rstring,acadErrorStatusText(es));
  } else
    acedRetStr(pArgs->resval.rstring);
  return (RSRSLT) ;
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
moogalm
Autodesk Support
Autodesk Support
Hi @Alexander.Rivilis
I feel the there is mismatch in calling convention, instead of _stdcall, it should have _cdecl, I'm not sure if this is giving a compiler error for you.
Alexander.Rivilis
Man Happy
The truth is somewhere in the middle:
AutoCAD 2019 x86:
?LoadManagedDll@@YG?AW4ErrorStatus@Acad@@PB_W@Z (enum Acad::ErrorStatus __stdcall LoadManagedDll(wchar_t const *))
AutoCAD 2019 x64:
?LoadManagedDll@@YA?AW4ErrorStatus@Acad@@PEB_W@Z (enum Acad::ErrorStatus __cdecl LoadManagedDll(wchar_t const *))
Expert Elite Member
waseefur.rahman
Hi Rivilis,
As when I add the Reference, it get some other error in my solution,
Could it be possible to load the Dll in command prompt itself,
I have done in .net to load the dll in command prompt itself, below is the coding.
ThisDrawing.SendCommand("FILEDIA" + vbCr & "0" + vbCr)
ThisDrawing.SendCommand("NETLOAD" + vbCr + "E:\waseef\property_isolation.dll" + vbCr)
ThisDrawing.SendCommand("FILEDIA" + vbCr & "1" + vbCr)
could you please advice how to achive the similar in C++.
Alexander.Rivilis
Hi Rivilis,
LoadManagedDll(L"E:\\waseef\\property_isolation.dll")
1. You have to insert definition of function LoadManagedDll as I posted above
2. You have to link with acdbmgd.lib
Expert Elite Member
