Linker error
Linker error
Linker error
Hi all
Can anyone give me a hint on this one. The problem occurs when using
actrTransactionManager->startTransaction();
Resulting in:
error LNK2019: unresolved external symbol "class AcApDocManager * __cdecl acDocManagerPtr(void)" (?acDocManagerPtr@@YAPAVAcApDocManager@@XZ) referenced in function "class AcTransactionManager * __cdecl acTransactionManagerPtr(void)" (?acTransactionManagerPtr@@YAPAVAcTransactionManager@@XZ)
Tore
This is exported from acad.exe and is in acad.lib. So, make sure that
acad.lib is included in your link.
wrote in message news:5029999@discussion.autodesk.com...
Hi all
Resulting in:
Tore
Tore:
Are you getting this error while linking a .dbx module? If so, it would
be expected since this function is in acad.exe, and .dbx modules are not
supposed to be linked to acad.exe. If it's not a .dbx module, you need to
link to acad.lib. 🙂
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
Hi
Yes, it's from a DBX module.
Thanks. Have to work around it.
Tore
