Linker error with C++ objectarx 2024
alain.holloway
alain.holloway
Hi there,
I'm getting this error message when I'm building my C++ project.
Error LNK2019 unresolved external symbol "void __cdecl operator delete(void *,enum std::align_val_t)"
Any idea why I'm getting this, the error is thrown by the linker when dealing with rxinit.obj of the rxapi.lib library
Thank you!!
moogalm
Autodesk Support
Autodesk Support
Did you link with `acpal.lib` ? it's part of SDK  ObjectARX\lib-x64
And may you share your build log.
msbuild /t:build /p:Configuration=Debug;Platform=x64 -fl -flp:logfile=MyProjectOutput.log;verbosity=diagnostic
alain.holloway
Yes I did, here's a list of all included libraries :
acad.lib
rxapi.lib
acge24.lib
acdb24.lib
acui24.lib
adui24.lib
accore.lib
ac1st24.lib
acpal.lib
Xmllite.lib
Version.lib
alain.holloway
Here's the log file as requested.
Thank you!
moogalm
Autodesk Support
Autodesk Support
Thanks for sharing the log.
Your project seems to be linking with older SDK too, try removing that. /LIBPATH:"C:\Autodesk\Autodesk_ObjectARX_2017_Win_64_and_32_Bit\lib-x64"
Are you using Visual Studio 2022 with VC 14.3 platform toolset ?
C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\bin\x86_amd64\link.exe /ERRORREPORT:PROMPT /OUT:"C:\GEBO_Autocad_2024_SetUp\CONVEYOR_TOOLS\Geboequi_2024.arx" /INCREMENTAL:NO /NOLOGO /LIBPATH:"C:\Autodesk\ObjectARX_for_AutoCAD_2024_Win_64bit_dlm\lib-x64" /LIBPATH:"C:\Autodesk\Autodesk_ObjectARX_2017_Win_64_and_32_Bit\lib-x64" acad.lib rxapi.lib acge24.lib acdb24.lib acui24.lib adui24.lib accore.lib ac1st24.lib acpal.lib Xmllite.lib Version.lib acad.lib rxapi.lib acge24.lib acdb24.lib acui24.lib adui24.lib accore.lib ac1st24.lib Xmllite.lib Version.lib /DEF:".\geboequi.def" /MANIFEST /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /manifest:embed /manifestinput:"C:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\Include\Manifest\dpiaware.manifest" /DEBUG /PDB:"C:\GEBO_Autocad_2024_SetUp\CONVEYOR_TOOLS\geboequi2024.pdb" /MAP /ASSEMBLYDEBUG /SUBSYSTEM:WINDOWS /TLBID:1 /DYNAMICBASE /NXCOMPAT /IMPLIB:"C:\Users\Administrator\Desktop\Code\GeboCAD_Atcd2024\x64\Debug Autocad 2024\Geboequi.lib" /MACHINE:X64 /DLL "x64\Debug Autocad 2024\geboequi.res"
AdditionalLibraryDirectories=C:\Autodesk\ObjectARX_for_AutoCAD_2024_Win_64bit_dlm\lib-x64;C:\Autodesk\Autodesk_ObjectARX_2017_Win_64_and_32_Bit\lib-x64;
tbrammer
This problem can also occur if you have _DEBUG defined while including STL or Windows headers.
If your release build works try to undefine _DEBUG while including these headers as explained here.
Also make sure that you don't link to debug libs explicitly.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
