Line drawing : Sending points from sendMessage to Autocad
Message 1 of 9
HI All,
I have *.arx, which i am loading into Autocad using appload *.arx file.
I intend to draw a line by using SendCmdToAcad
read(string cmd )
wchar_t wptr[50] = {0};
cmd += "\n";
char2wchar(cmd.c_str(), wptr);
SendCmdToAcad(wptr);
static void SendCmdToAcad(ACHAR *cmd)
COPYDATASTRUCT cmdMsg;
cmdMsg.dwData = (DWORD)1;
cmdMsg.cbData = (DWORD)(_tcslen(cmd) + 1) * sizeof(ACHAR);
cmdMsg.lpData = cmd;
HWND hwnd = adsw_acadMainWnd();
SendMessage(hwnd, WM_COPYDATA, NULL, (LPARAM)&cmdMsg);
The sequence is
command: _line   -> SendMessage() works fine sends to autocad and SendMessage() returns from call
Specify first point: 10,20,0
Specify next point or [Undo]:   : After sending 1st point sendmessage blocks here , does not return from the call, until i explicitly hit "ENTER" key on Autocad window.
How do i solve the problem programmatically of hitting "enter" key after point.
In my read() -> above If i do
cmd += "\n\n";
then it escapes reading the second point as well
Please let me know, any pointers would be greatly appreciated. I need to get this done.
Thank you.
Observed Behaviour
10,20,30\0 : reads point on same line as in (10,20,30|123,300,10)
                    no | in real life just indicative of end of 1 point
10,20,30\n : blocks
10,20,30\n\n : skips the next point reading
10,20,30(1char)\n: if (1char) any character is added it goes fine, but point becomes invalid
Replies (8)
Message 2 of 9
tbrammer
Have you tried to use acDocManager->sendStringToExecute(doc, command)  instead?
This works fine for me:
 acDocManager->sendStringToExecute(acDocManager->curDocument(), L"_LINE 10,0,0 10,20,0 \n");
Note that I use one space ' ' to terminate the point and a '\n' to terminate the LINE command.
Maybe it also works for the COPYDATASTRUCT approach.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 3 of 9
tbrammer
By the way: Is there a special reason why you draw a line like this instead of creating in directly in the database?
Message 4 of 9
no reason, this was the method i saw on internet , and used it.
Added ' ' (single space) not working with COPYDATASTRUCT.
Could you please give me example of doing it by database method.
Message 5 of 9
tbrammer
I would recomment to use acDocManager->sendStringToExecute()  instead of SendMessage(hwnd, WM_COPYDATA, ..).
But you should always prefer to create objects directly in the database, because it gives you much better control and performance than sending commands! Sending "_LINE 0,0,0 100,0,0 \n" to AutoCAD doesn't guarantee that it really draws a line from 0,0,0 to 100,0,0. There might be object snap involved causing a totally different start- or endpoints to be snapped.
// Add entity ent to the modelspace of the current drawing.
Acad::ErrorStatus postToDb(AcDbEntity* ent, AcDbObjectId& objId)
	Acad::ErrorStatus      es;
	AcDbBlockTableRecord *pModelSpace;
	AcDbDatabase *pDB = acdbHostApplicationServices()->workingDatabase();
	AcDbObjectId IdModelSpace = acdbSymUtil()->blockModelSpaceId(pDB);
	if ((es = acdbOpenObject(pModelSpace, IdModelSpace, AcDb::kForWrite)) == Acad::eOk)
		es = pModelSpace->appendAcDbEntity(objId, ent);
		pModelSpace->close();
		if (es == Acad::eOk)
			ent->close();
	return es;
// Create a line in the modelspace of the current drawing.
AcDbObjectId AddLine(AcGePoint3d p1, AcGePoint3d p2)
	AcDbObjectId objId;
	AcDbLine *line = new AcDbLine(p1, p2);
	line->setDatabaseDefaults();
	Acad::ErrorStatus es = postToDb(line, objId);
	if (es != Acad::eOk)
		delete line;
	return objId;
Message 6 of 9
Thank you tbrammer.
I also need to capture the mouse event clicked on line/symbol/text entities.
Could you please direct me to sample code of doing it.
Ive posted a question on this with title "C++: Mouse Event handling"
Thanks.
Message 7 of 9
I need to send points to Autocad through Sendmessage(), but stuck
with not able to send points to autocad, due to the listed problem in my query.
If anybody knows any workaround to send points to autocad using sendmessage, please let me know,
Thanks.
Message 8 of 9
This way also it works
string AutoCmd="1234556.89,6823463,50,50";
wchar_t *wpt = (wchar_t *)calloc(AutoCmd.length(), sizeof(wchar_t));
char2wchar(AutoCmd.c_str(), wpt);
acedCommand(RTSTR, _T("_POINT"), RTSTR, wpt , RTNONE);
free(wpt);
thanks,
Message 9 of 9
moogalm
Autodesk Support
Autodesk Support
I recommend you to follow @tbrammer solution.
Please note your code might be work, but you will be not able to scale or migrate to newer versions of AutoCAD, your application may not work post fiber world. i/e ACAD 2015.
