Installing ObjectArx
cjacobs
Message 1 of 11
cjacobs
ObjectARX won't install.
Replies (10)
Message 2 of 11
it says what the problem is
what are you leaving out?
Message 3 of 11
cjacobs
What am 'I" leaving out?! You folks are the one with the answers! I'm just trying to learn how to use Visual Studio Community 2019 to develop AutoCAD 2020 plugins. Simple as that. I've been following instructions. Step one - install Visual Studio. Step two - install ObjectArx. This is what I get: (see attachment). I get the same message when I try installing the Wizards. What's up with your install files! I'm not going to spend thousands of dollars to upgrade to a subscription service for Visual Studio! (Note: all lessons and instructions say the wizards WILL work with the free "community" version of Visual Studio.)
Message 4 of 11
dgorsman
Steady.  Anyone here without the Autodesk icon is just a user.
There isn't a need to install or use the wizards to create managet dotNET DLLs or unmanaged C++ ARX/CRXs.  Just some knowledge of the language, VS IDE, and the references extracted from the SDK.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 5 of 11
cadffm
2019 isn't 2017..
Sebastian
Message 6 of 11
cjacobs
You say “just some knowledge of the language, VS IDE, and the references extracted from the SDK”. Care to pass on that “knowledge”, please. Otherwise, your response is worthless.
I can see I’m on my own here. AutoCAD subscription technical support is non-existent.
Message 7 of 11
Alexander.Rivilis
@cjacobs
In order to using ObjectARX SDK 2020 and ObjectARX Wizard 2020 you have to install Visual Studio 2017 - not 2019 but 2017.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 8 of 11
cjacobs
Finally! Somebody who knows what they are talking about. Thanks, problem solved.
Message 9 of 11
I tend to think you mean that VS2019 can't also be installed.
I'm having no luck using the Wizard installer even though I also have VS2017 installed.
Message 10 of 11
Alexander.Rivilis
You seem to are confusing with difference between ObjectARX SDK and ObjectARX Wizard. You have to previously install ObjectARX SDK 2020 before installing ObjectARX Wizard 2020. ObjectARX Wizard have to be installing with Administrator rights and UAC turned off.
Expert Elite Member
Message 11 of 11
Mahass
Same propblem, i have VS2019, SDK 2022 and i installed objectARX Wizared 2022 as admin but not working!!
i do not find it when creating new C++ project ?
Any suggestions please?
