Inside AcEditorReactor doesnot work acedCommand
majklha
majklha
I try to redefine action for double click to entity, but only for some entity types. Eg. for attribute I want to run standard Autodesk dialog. But I am not able to run th acedCommand function inside beginDoubleClick reactor function.
This code doesnot work, and error is -5001 (other error).
class CMajAcEditorReactor : public  AcEditorReactor
void CMajAcEditorReactor::beginDoubleClick(const AcGePoint3d &clickPoint)
	CMajAc::SetVarInt(L"DBLCLKEDIT", 0);
	acutPrintf(L"\nBegin Double click");
	ads_name vybrEntity;
	double *ptPick = asDblArray(clickPoint);
	if(acedSSGet(L"_:n", ptPick, NULL, NULL, vybrEntity) == RTNORM) //:n - umožní výběr subentity
		ads_name entita;
		acedSSName(vybrEntity, 0, entita);
		acedSSFree(vybrEntity);
		int err = acedCommandS(RTSTR, _T("EATTEDIT"), RTENAME, entita, RTNONE);
		return;
If I normally select the attribut (or block) it work properly (almost identical code):
void Pokus()
	if(acedSSGet(L"_:n", NULL, NULL, NULL, vybrEntity) != RTNORM) //:n - umožní výběr subentity
		return;
	ads_name entita;
tbrammer
I don't think that it is possible to use acedCommandS() from within a reactor.
You could try to register a command and call it using acDocManager->sendStringToExecute(..).
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
daniel_cadext
or beginExecuteInCommandContext
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
