inserting block like acad INSERT
Hi I want to konow how to insert block in dwg like in acad INSERT command. I want to see block and block changes when choosing insertion point,scale and rotation. Examples on adn doesn't show block when choosing insertion point and rotation. Thanks Simon
You'll need to use an AcEdJig for that. Not too terribly difficult. Take a look at the ObjectARX reference and the sample application that comes in the SDK - one of them shows you how to jig an ellipse. Give it a try and post back if you have problems. -Rich "simon pelicon" wrote in message news:40920cce$1_2@newsprd01... > Hi > > I want to konow how to insert block in dwg like in acad INSERT command. > I want to see block and block changes when choosing insertion point,scale > and rotation. Examples on adn doesn't show block when choosing insertion > point and rotation. > > Thanks > > Simon > >
Once I tried to insert a block with attributes thru AcEdjig - but my problem was with the block attributes - I didn't able to turn them off like autoCAD insert command... At that time I didn't spend much time on that - but within 2/3 weeks I've to solve that problem. Thanks -Partha "Justavian" wrote in message news:40925210$1_1@newsprd01... > You'll need to use an AcEdJig for that. Not too terribly difficult. Take a > look at the ObjectARX reference and the sample application that comes in the > SDK - one of them shows you how to jig an ellipse. Give it a try and post > back if you have problems. > > -Rich > > > "simon pelicon" wrote in message > news:40920cce$1_2@newsprd01... > > Hi > > > > I want to konow how to insert block in dwg like in acad INSERT command. > > I want to see block and block changes when choosing insertion point,scale > > and rotation. Examples on adn doesn't show block when choosing insertion > > point and rotation. > > > > Thanks > > > > Simon > > > > > >
Look at acedGetVar() for sysvar "attreq" this may be what you need. jon "simon pelicon" wrote in message news:40920cce$1_2@newsprd01... > Hi > > I want to konow how to insert block in dwg like in acad INSERT command. > I want to see block and block changes when choosing insertion point,scale > and rotation. Examples on adn doesn't show block when choosing insertion > point and rotation. > > Thanks > > Simon > >
i have a similar problem ...
I have a dwg file wich has some custom entities .
I have an application loaded that contains the custom entity class.
I try to insert the dwg in a new drawing ..It works... But if in the insert dialog box from autocad I check the explode option
it doesn't work .
I overrrided deepclone function . It is basicaly the same as the example in the documentation or samples.
So my problem is :
If i choose just insert : the pOwner parameter from deepclone
is Ok. By ok I meen i can make a cast to AcDbBlockTableRecord and add the cloned entity ....
If i check the explode option the pOwner is not ok anymore...
I can't make a cast to AcDbBlockTableRecord ... but i can make a cast to AcDbBlockTable !! ...(the object is primary)
In the samples this case is treatead as : eInvalidOwner
One more thing ...if i don't choose insertion point the owner is again ok ..
Help Help Help
