Insert block from another database
I am new to ObjectARX so please bear with me if I ask something already answered.
Now I like to insert a block from another drawing(source drawing) in current drawing. I would not like to insert the whole drawing and delete all others. now from the sample I found in this newsgroup/sample/google,
1. use readDwgFile to read source drawing.
2. pDwgBlockTbl->getAt("TPLT-DR", pBlkTblRcd, AcDb::kForRead ) to get the objectid of block
3. pBlkTblRcd->getBlockReferenceIds( list );
4. wblock to a temp database
AcDbDatabase *pCurrentDB = acdbHostApplicationServices()->workingDatabase();
es = pDwg->wblock(pTempDb, list, AcGePoint3d(0,0,0));
5. insert in current drawing
es = pCurrentDB->insert(AcGeMatrix3d::kIdentity, pTempDb);
now I have 2 problem, if there are more than 1 INSERT in source drawing, then all of them will insert in current drawing. I fix by remove all but 1 left in AcDbObjectIdArray list;
2nd if there is no INSERT for that block in source drawing. only block definition exist in blocktable. How I can make it work.
I tried:
AcDbBlockReference *pWindowBlock =new AcDbBlockReference(point, blockId);
It crash and I understand it try to create a new blockReference in current drawing which does not exist the definition yet.
How I can make this work?
actually block definition is all I want. so how to copy a block definition from one database to another if there is no instance (INSERT) in source database?
Thank you,
Wes
AutoCAD 2004, Visual Studio 2002, Windows XP pro
I tried:
Thank you,
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
