Import xml problems
Import xml problems
Import xml problems
Is it possible to insert and view XML data in to AutoCAD 2d (2016). We do not use Civil 3D software.
Virupaksha_aithal
Autodesk Support
Autodesk Support
I do not think AutoCAD has any API which can take XML file and create geometry. However, you can write a custom command which can take a XML file and create AutoCAD geometry using AutoCAD API’s
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
Thank you.
