IACADENTITY Error
IACADENTITY Error
hamza_ishtiaqMTF8E
IACADENTITY Error
hamza_ishtiaqMTF8E
Hello Team,
Good Day, I need help in resolving an error i am encountering in my project that i am upgrading from 2020 to 2021. Earlier i was using ObjectARX 2020 files now i am using ObjectARX 2021 files and using Visual studio 2019 as mentioned in Autodesk documentation. I need your help to resolve below error please.
error BC30652: Reference required to assembly 'AXDBLib, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' containing the type 'IAcadEntity'. Add one to your project.
It would be appreciated if you may share migration guide from 2020 to 2021.
tbrammer
Usually <ARX>\inc\dbxHeaders.h is included either directly or indirectly in stdafx.h. This header has the line
#pragma comment (lib ,"axdb.lib")
which should do the trick.
Please make sure that you have adjusted the project settings to the correct <ARX> directory
  • C/C++ ->General->Additional Include Directories
  • Linker->General->Additional Library Direcories
These directories (and other settings) might be set by property sheets (.props files).
In Visual Studio you can bring up the property manager window via menu [View].[Property Manager]:
Each project configuration can have it's own set of property pages.
If you add a new project configuration for Arx 2021, you should use an appropriate property page for it as well.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
