Sorry for false alarm 🙂 Actualy my message handle is called (i don't know
why i thougt it not :(, maybe i work to hard 🙂 But the problem was that
AutoCAD need repaint and as always i forgot how to do that, so i needed a
little bit time to remember and then add few lines to my message handler :
acedGetAcadFrame()->SetFocus();
acedUpdateDisplay();
I always forgot to add the last line(and start searching another way :).
Maybe you know why i need 2 SetFocus() call's to force autocad update it's
window, or maybe there is another way?
"Justavian" wrote in message
news:BDD7BBA9820629DD304F128E3772378D@in.WebX.maYIadrTaRb...
> Hmmm.... i don't have a problem with that - but you might want to try to
> fake out AutoCAD. Send it a mouse move message, or a button down message.
> Try adding this:
> ::PostMessage(adsw_acadDocWnd(),WM_LBUTTONDOWN,NULL,NULL);
> I use that little call to force Acad to go into my point filter. In my
> case, i'm using the mouse wheel perform various additional functions.
> However, ACAD's point filter doesn't care about the mouse wheel, so i had
to
> fool into thinking something was happening like that.
> By the way - i'm impressed you got that up and running so quickly! Good
> job... Let me know if i can help ya anymore.
> -Rich
> "Mindaugas Bliudzius" wrote in message
> news:83517759AF7CC17459338980340C13A9@in.WebX.maYIadrTaRb...
> > Hi,
> > I did second way, everything now cool, just when AutoCAD finished his
> > job(deleting), i need to move mouse little bit to get started whith my
> > message handle :((( Maybe you know what can be the problem?
> > Thank's
> > news:25430528AC7FB2969315F82B1C93098C@in.WebX.maYIadrTaRb...
> > > You could check what the current selection set is by using
> > > acedSSGet("I",NULL,NULL,NULL,ssname) - you could check this on the
first
> > > objectErased. With that you could assemble a total number of objects
> > being
> > > erased, and perhaps you could increment a global variable to figure
out
> > > whether you were on the last one.
> > > Another (more complicated) solution is to use a message handler.
Create
> a
> > > CWnd derived class that can receive some sort of user message (like
> > > WM_MYENT_ERASED). Everytime your objectErased() fucntion fires, you
use
> > > PostMessage(WM_MYENT_ERASED, wParam, lParam). By posting it, rather
> than
> > > using SendMessage, the WM_MYENT_ERASED messages won't get processed
> > > immediately. What this means is that those messages will build up in
> the
> > > message queue for that CWnd derived class. When AutoCAD gets finished
> > > processing all of the objectErased() messages, that's when the first
of
> > the
> > > WM_MYENT_ERASED messages will begin being processed. In your handler
> for
> > > that message, use PeekMessage() to get ALL of the WM_MYENT_ERASED
> messages
> > > that have been posted. You can then do whatever processing needs to
be
> > done
> > > in a bulk format.
> > > There may be easier ways than the one i just listed, but i've found a
> lot
> > of
> > > uses for that procedure. I have an application that does a LOT of
> > database
> > > operations. Those operations are triggered by things that happen in
the
> > > drawing. Say a move operation can cause my app to tag into a database
> and
> > > check certain values. If 100 objects are moved at once, it would
access
> > the
> > > database 100 different times (since i'd detect that move using a
reactor
> > > that would fire for each object). Using this message handler
technique,
> i
> > > can bulk process all 100 objects with a single (albeit long) SQL
> > statement.
> > > Needless to say this is significantly faster.
> > > -Rich
> > > news:92620D927A808C5C031539330C40D235@in.WebX.maYIadrTaRb...
> > > > Hi,
> > > > I need to modify my drawing after point is deleted, by if user
> > selects
> > > > not one point but a lot, then it is
> > > > crazy to modify a drawing after each objectErased(), because take a
> lot
> > of
> > > > time to modify my drawing, so is there any way to now how many
points
> > it's
> > > > selected to delete or maybe the end of delete operation?
> > > > Thank's
