How to get psltscale system variables of the specified layout
adn019LKFW
adn019LKFW
In the example drawing, psltscale of "layout1" is 1, and psltscale of "layout2" is 0. What is the correct way to get the psltscale in the specified layout. Function AcDbDatabase::psltscale() does not provide parameter for specifying layout or modelspace.
tbrammer
I think the only possible way without switching the layout is to analyze the DXF data of the AcDbLayout.
Here are screenshots of ArxDbg's command SNOOPDB:
You can retrieve the DXF resbuf list like this:
AcDbDatabase *pDB = acdbHostApplicationServices()->workingDatabase();
AcDbObjectId idLayoutDict(pDB->layoutDictionaryId());
ads_name dict;
acdbGetAdsName(dict, idLayoutDict);
struct resbuf* rb = acdbDictSearch(dict, L"Layout1", 0);
if (rb)	{
	// find 100, "AcDbLayout", 1, "Layout1", 70 and get the int value
	acutRelRb(rb);
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
adn019LKFW
Thank you for your reply, I'll try it.
