How to get name of inherited class of selected entity
majklha
Message 1 of 8
majklha
If I select entity from DWG, by ssgeg function, I have a general entity pointer (AcDbEntity* pEntity). How I get a real class name of this netity (eg. AcDbLine or AcDbText, etc...). Like string.
pEntity->className() return "AcDbEntity"
pEntity->isA()->desc()->className() return some unsence ("AcRxObject").
I, of course, dont know, what type pEntity is. I cannot use AcDbLine::desc(pEntity).....
Thanks.
Replies (7)
Message 2 of 8
daniel_cadext
    static auto entsel()
        AcGePoint3d pnt;
        ads_name name = { 0L };
        int res = acedEntSel(L"\nSelect it: ", name, asDblArray(pnt));
        AcDbObjectId id;
        if(auto es = acdbGetObjectId(id, name); es != eOk)
            return std::make_tuple(Acad::PromptStatus::eError, id, pnt);
        return std::make_tuple(Acad::PromptStatus(res), id, pnt);
    static void AcRxMyApp_idoit(void)
        auto [es, id, pnt] = entsel();
        if (es == Acad::PromptStatus::eNormal)
            AcDbEntityPointer pEnt(id);
            acutPrintf(pEnt->isA()->name());
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 3 of 8
majklha
easy reply is:
pEntity->isA()->name();
Message 4 of 8
daniel_cadext
easy reply is: thank you : )
Message 5 of 8
majklha
Of course, thank you. I forgot...
Sorry, it shouldn't be any irony. Your answer has been very helpful.
I wrote "easy answer" for others. 🙂
Message 6 of 8
1127204185
Hello! The result is AcDbLine or AcDbText. Can I get Line or Text? A zero value similar to DXF。thank you!
Message 7 of 8
daniel_cadext
This should return the dxf name
pEnt->isA()->dxfName()
Message 8 of 8
1127204185
thank you!
