How to fix COMPtr' problem?
D_D_K
D_D_K
After running the following code, my cad crashes at the end.
because there are some custom functions with parameter IAcadBlocksPtr, so I used it like below:
CComQIPtr<IAcadApplication> pApp(acedGetIDispatch(FALSE));
CComPtr<IAcadDocument> pDoc;  //getcurrent doc
IAcadBlocksPtr pblks;
hR = pDoc->get_Blocks(pblks);
//do something Ok
pblks.Release();
HRESULT hr = pDoc->Close(vb); //Ok
pDoc.Release();
return true;// <---crash;
How do I avoid this?
Alexander.Rivilis
1. pDoc is not initilaize
2. pDoc release twice as far as you call pDoc.Release() and destructor of pDoc also call pDoc.Release()
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
D_D_K
Hi sir,
the reason I call pDoc.release(); because when using the original code below -> cad crashes first.
I'm not sure where is wrong. these variables are initialized and working correctly.
pApp->get_ActiveDocument(&pDoc);
//do something Ok
pblks.Release();
HRESULT hr = pDoc->Close(vb); //success
Alexander.Rivilis
Are you trying to close active document?
It is look like error not in this code.
Expert Elite Member
D_D_K
Thanks sir,
I have reviewed my code. the error comes from a subroutine.
Remove it and now the code works fine.
