How to display values other than double in OPM when using element grouping?
maisoui
maisoui
I created a COM wrapper to display properties of my custom entity property palette. My entity contains several points and for each point, you can define a string. So I use GetGroupCount and GetElementGrouping to display a property with a spin control to go to previous or next point (similar to vertex property of AcDbPolyline). So for each point, it will display X, Y and Z values of the position and normally the text. But, it seems like when I'm using element grouping, only double values are understood. I tried to display string or bool, but it doesn't work:
varOut->vt = VT_BOOL;
varOut->boolVal = TRUE;
or
varOut->vt = VT_BSTR;
varOut->bstrVal = ::SysAllocString(_T("TEST"));
or
BSTR str = T2BSTR(_T("TEST"));
*varOut = CComVariant(str);
 Does anyone have a suggestion?
Jonathan
maisoui
Yes, it could have been. Problem, this sample only displays double values...
Jonathan
Balaji_Ram
Hi Jonathan,
Sorry, the "IOPMPropertyExpander" is only capable of handling doubles.
You will find this in the documentation on "IOPMPropertyExpander" :
Note As of this writing, this interface is used only for point properties whose type is a VARIANT that contains a SAFEARRAY of doubles.
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
maisoui
Hi Balaji,
Sorry, I missed that. Situation is now clear (I will try to find a workaround). Thank you.
Jonathan
Jonathan
