How to compare points in a custom line entity
I have a custom line entity called Myline. I know that this entity have two methods : Myline.startpoint() and myline.endpoint().
I need to compare these points and check if these points are connected together or not. For this reason, I collect all points in a vector and then compare each one to another.
Could you help me how can I do that? Can I compares points in a normal way like below:
if (point1==point2) {
Or I need to use isequalto function as below:
if (point1.isequalto(point2, AcGeContext::gTol)==Adesk::KTrue {
But all above ways return errors in my code.
Alexander.Rivilis
Read inc\gepnt3d.h:
inline bool AcGePoint3d::operator == (const AcGePoint3d& p) const
    return this->isEqualTo(p);
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Thank you Alexander!
Then I can use == operator.
But why my code returns Exception error?
Alexander.Rivilis
@Anonymous  написал (-а):
I think need to look at this code.
Expert Elite Member
