How do you display a bmp using the AcGiGeometry::image method?
Does anyone know what format the imageSource needs to be in? The AcGiImageBGRA32 takes a pointer to a AcGiPixelBGRA32, I'm assuming this is an array of the pixels. Is it in a top-down layout or bottom-down? I'm also assuming from the BGRA designation that the colors of each pixel are reversed from that of a bmp. Thanks for looking at this, the SDK had little to say and I didn't see anything on the forum or with Google.
Balaji_Ram
Hi Darcy,
Here is a sample code snippet to explain this :
AcGiImageBGRA32 giImage;
AcGiPixelBGRA32 *pixels = new AcGiPixelBGRA32[ImageWidth * ImageHeight];
for (int i = 0; i < ImageWidth; i++)
	for (int j=0; j < ImageHeight; j++)
		pixels[(j * ImageWidth) + i].setBGRA(blue, green, red, alpha);
giImage.setImage(ImageWidth, ImageHeight, pixels);
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
BigBadBernie
What happens to the new AcGiPixelBGRA32 Array?
When I create it in Line:
I have to delete it at some point.
When I do this, then AutoCAD crashes.
What is wrong?
