How did you learn about using ObjectARX?
Good morning, im learning about autocad customization, but right now im only able to code AutoLisp routines and want to progress. Im looking for a way to learn about ObjectARX and Visual Lisp, but i cant find any books or anything on the web, only a few command lists that doesnt show how all of it works. So i need you guys to tell me how did you started learning, to start following your path 😛
Thanks!
(sorry for my english)
I started with the ObjectARX documentation that comes along with the SDK. I found it a bit frustrating to dig into and find exactly what I was trying to accomplish, but for the most part, it's all explained there. If you need to find reference on C++ or VB.NET programming languages though, you'll need to find it elsewhere!
Sign up on the Autodesk Developer Network if you haven't already. They have a number of great resources that will help get you started:
http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112
I'd pay particular attention to the My First AutoCAD Plugin guide and the self-paced ObjectARX training and .NET training labs.
Also, be sure to check out the ObjectARX FAQ page, as it may answer the simple questions that aren't really mentioned elsewhere:
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=773128
zrobert
Hi;
For start with ObjectARX, try http://arxdummies.blogspot.hr/. It contains great step by step tutorials.
ObjectARX SDK documentation has also good instructions for setting up projects (and all other things... :)).
On the same page you can download ObjectARX wizard to.
Another GREAT material is http://au.autodesk.com/au-online/classes-on-demand/class-catalog/2014/autocad/sd6148.
Enjoy!
zrobert
Ups! Sorry for repetition some advices of architectOfIdeas.
