how can i get selected 3d object?
I want use mouse to get selected object .then append it to other.How can i do it?
Thanks in advange
leefsma
Sorry but it is very unclear what you are trying to do exactly...
My suggestion would be to use methods such as acedEntSel in order to prompt the user for an entity, an AcDb3dSolid for example. then you can use "AcDb3dSolid::booleanOper" in order to merge it with an existing one. Have a look in the ObjectARX help files if you need more details about the methods I mentionned.
I hope it helps.
Philippe Leefsma
Developer Consultant
Developer Technical Services
Global Subscription & Support
Autodesk EMEA
www.autodesk.com/joinadn
