How can I convert this code from ObjectAXR, which works with toolpalette groups, to .NET C#?
artillis_prado
Message 1 of 1
artillis_prado
This code creates a group in the Tool Palette or retrieves an existing one, and links it to the palette. My question is how to do it in .NET C#.
void MyUtilities::CreateToolPaletteGroup(System::String^ toolPaletteGroupName)
	CAcTcUiToolPaletteSet *pTpset = AcTcUiGetToolPaletteWindow();
	CAcTcUiToolPaletteGroup *pRootTpgroup = pTpset->GetToolPaletteGroup(FALSE);
	CAcTcUiToolPaletteGroup *pMyToolPaletteGroup = NULL;
	pMyToolPaletteGroup = pRootTpgroup->FindGroup(StringToCIF(toolPaletteGroupName), TRUE);
	if(pMyToolPaletteGroup == NULL)
	{ // Does not exist, lets create it
		// Create a new Palette Group
		CAcTcUiToolPaletteGroup * pMyToolPaletteGroup = NULL;
		pRootTpgroup->Clone(pMyToolPaletteGroup);
		pMyToolPaletteGroup->Reset();
		pMyToolPaletteGroup->SetName(StringToCIF(toolPaletteGroupName));
		// Any Palette can be found in the "All Palettes group"
		CAcTcUiToolPaletteGroup *pAllPalettesGroup = pTpset->GetAllPalettesGroup();
		CAcTcUiToolPalette *pMechanicalPalette = pAllPalettesGroup->FindPalette(ACRX_T("Mechanical"), NULL);
		// Add it to the palette group
		pMyToolPaletteGroup->AddItem(pMechanicalPalette);
		// Create a new palette and add it to the palette group
		CAcTcUiManager *pToolPaletteManager = AcTcUiGetManager();
		CAcTcUiToolPalette *pMyToolPalette = pToolPaletteManager->CreatePalette(ACRX_T("MyPalette"));
		pMyToolPaletteGroup->AddItem(pMyToolPalette);
		pRootTpgroup->AddItem(pMyToolPaletteGroup);
	// Set the newly create Palette group as active
	pTpset->SetActivePaletteGroup(pMyToolPaletteGroup);
I found this code in ObjectAXR, but I work with .NET C#. Is there a way to achieve the same logic in .NET C#?
Code ObjectAXR
https://adndevblog.typepad.com/autocad/2013/06/working-with-toolpalette-groups-using-net.html
Replies (0)
