Help on ADO with ObjectARX
05:50 AM
I am just trying to get connection to external database using ado
#import directive. Infact I just merged the code from two samples and they works fine separately but when I pull them together its showing following errors:
c:\temp\aaa\debug\msado15.tlh(2667) : error C2059: syntax error : 'constant'
c:\temp\aaa\debug\msado15.tlh(2667) : error C2238: unexpected token(s) preceding ';'
code:
// aaa.cpp : Initialization functions
#include "StdAfx.h"
#include "StdArx.h"
#include "resource.h"
#include
#import "C:\Program Files\Common Files\System\ado\MSADO15.dll" rename("EOF", "ADOEOFile")
void mydbcon();
struct StartOLEProcess{
StartOLEProcess( ) {
::CoInitialize(NULL);
~StartOLEProcess( ) {
::CoUninitialize( );
} _start_StartOLEProcess;
// This command registers an ARX command.
void AddCommand(const char* cmdGroup, const char* cmdInt, const char* cmdLoc,
const int cmdFlags, const AcRxFunctionPtr cmdProc, const int idLocal = -1);
// NOTE: DO NOT edit the following lines.
//{{AFX_ARX_MSG
void InitApplication();
void UnloadApplication();
//}}AFX_ARX_MSG
//{{AFX_ARX_ADDIN_FUNCS
//}}AFX_ARX_ADDIN_FUNCS
// ObjectARX EntryPoint
extern "C" AcRx::AppRetCode
acrxEntryPoint(AcRx::AppMsgCode msg, void* pkt)
switch (msg) {
case AcRx::kInitAppMsg:
// Comment out the following line if your
// application should be locked into memory
acrxDynamicLinker->unlockApplication(pkt);
acrxDynamicLinker->registerAppMDIAware(pkt);
InitApplication();
break;
case AcRx::kUnloadAppMsg:
break;
return AcRx::kRetOK;
// Init this application. Register your
// commands, reactors...
//{{AFX_ARX_INIT
//}}AFX_ARX_INIT
acedRegCmds->addCommand("MYDBCON_COMMANDS",
"dblog",
"dblog",
ACRX_CMD_MODAL,
mydbcon);
// TODO: add your initialization functions
// Unload this application. Unregister all objects
// registered in InitApplication.
//{{AFX_ARX_EXIT
//}}AFX_ARX_EXIT
// TODO: clean up your application
acedRegCmds->removeGroup("HELLOWORLD_COMMANDS");
// This functions registers an ARX command.
// It can be used to read the localized command name
// from a string table stored in the resources.
const int cmdFlags, const AcRxFunctionPtr cmdProc, const int idLocal)
char cmdLocRes[65];
// If idLocal is not -1, it's treated as an ID for
// a string stored in the resources.
if (idLocal != -1) {
HMODULE hModule = GetModuleHandle("Adskaaa.arx");
// Load strings from the string table and register the command.
::LoadString(hModule, idLocal, cmdLocRes, 64);
acedRegCmds->addCommand(cmdGroup, cmdInt, cmdLocRes, cmdFlags, cmdProc);
} else
// idLocal is -1, so the 'hard coded'
// localized function name is used.
acedRegCmds->addCommand(cmdGroup, cmdInt, cmdLoc, cmdFlags, cmdProc);
void mydbcon()
acutPrintf("\nCreating db connection!");
// define our variables which will be used as references to the
// Connection and Recordset objects
ADODB::_ConnectionPtr con = NULL;
ADODB::_RecordsetPtr rec = NULL;
// define variables to read the Author field from the recordset
ADODB::FieldPtr pAuthor;
_variant_t vAuthor;
char sAuthor[40];
// create two strings for use with the creation of a Connection
// and a Recordset object
bstr_t sConString;
bstr_t sSQLString;
// create a variable to hold the result to function calls
HRESULT hr = S_OK;
// long variable needed for Execute method of Connection object
VARIANT *vRecordsAffected = NULL;
// create a new instance of an ADO Connection object
hr = con.CreateInstance(__uuidof(ADODB::Connection));
acutPrintf("Connection object created.\n");
// open the BiblioDSN data source with the Connection object
sConString = L"Provider=Microsoft.Jet.OLEDB.4.0; "
L"Data Source=C:\\Temp\\mydb.mdb";
con->Open(sConString, L"", L"", -1);
acutPrintf("Connection opened.\n");
// create a Recordset object from a SQL string
sSQLString = L"SELECT password FROM tbl_master where user_id=='mal';";
rec = con->Execute(sSQLString,
vRecordsAffected,
1);
acutPrintf("SQL statement processed.\n");
// point to the Author field in the recordset
pAuthor = rec->Fields->GetItem("Author");
// retrieve all the data within the Recordset object
acutPrintf("Getting data now...\n\n");
while(!rec->ADOEOFile) {
// get the Author field's value and change it
// to a multibyte type
vAuthor.Clear( );
vAuthor = pAuthor->Value;
WideCharToMultiByte(CP_ACP,
0,
vAuthor.bstrVal,
-1,
sAuthor,
sizeof(sAuthor),
NULL,
NULL);
acutPrintf("%s\n", sAuthor);
rec->MoveNext( );
acutPrintf("\nEnd of data.\n");
// close and remove the Recordset object from memory
rec->Close( );
rec = NULL;
acutPrintf("Closed an removed the "
"Recordset object from memory.\n");
// close and remove the Connection object from memory
con->Close( );
con = NULL;
acutPrintf("Closed and removed the "
"Connection object from memory.\n");
Please help me.
ObjectARX 2000
VS 6.0
Windows 2000 SP4
ADO 2.8
Regards
Alam
code:
#include "StdAfx.h"
#include "StdArx.h"
#include
void mydbcon();
//{{AFX_ARX_MSG
//}}AFX_ARX_MSG
switch (msg) {
InitApplication();
break;
break;
//{{AFX_ARX_INIT
//}}AFX_ARX_INIT
"dblog",
"dblog",
ACRX_CMD_MODAL,
mydbcon);
//{{AFX_ARX_EXIT
//}}AFX_ARX_EXIT
char cmdLocRes[65];
} else
void mydbcon()
_variant_t vAuthor;
char sAuthor[40];
bstr_t sConString;
bstr_t sSQLString;
HRESULT hr = S_OK;
vRecordsAffected,
1);
vAuthor.Clear( );
0,
vAuthor.bstrVal,
-1,
sAuthor,
sizeof(sAuthor),
NULL,
NULL);
rec->MoveNext( );
rec->Close( );
rec = NULL;
con->Close( );
con = NULL;
Please help me.
ObjectARX 2000
VS 6.0
Windows 2000 SP4
ADO 2.8
Regards
Alam
