Header File Issues
Header File Issues
john4TMYX
Header File Issues
john4TMYX
Hi guys,
My language is is C++ for the plugin development. For the debug build, I found the following lines in the stdafx.h give me a lot of problems.  When I keep as it is, then I can't build a debug version of plugin which links with other libs which are also compiled in debug mode. How your guys have solved this problem?
//- 'DEBUG workaround' below prevents the MFC or ATL #include-s from pulling
//- in "Afx.h" that would force the debug CRT through #pragma-s.
#if defined(_DEBUG) && !defined(AC_FULL_DEBUG)
#define _DEBUG_WAS_DEFINED
#undef _DEBUG
#pragma message (" Compiling MFC / STL / ATL header files in release mode.")
#endif
daniel_cadext
Yeah, you have to link with acad’s libraries, which are release, and linked with release MFC/CRT.
So basically, your local modules will need to be pseudo debug, compiler optimizations turned off, export debug info.
Check out one of the samples in the SDK.
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
