error LNK2019: unresolved external symbol "public: static bool __cdecl AcRxClass::isDerivedFrom(class AcRxClass const *,class AcRxClass const *)" (?isDerivedFrom@AcRxClass@@$$FSA_NPEBV1@0@Z) reference
alexander.lundinPUNY4
I get these errors when compiling .arx solution for AutoCAD2024.
I'm linking with the current SDK and these libs:
<AdditionalDependencies>accore.lib;acad.lib;acui24.lib;adui24.lib;AcPal.Lib;rxapi.lib;acdb24.lib;acge24.lib;%(AdditionalDependencies)</AdditionalDependencies>
4>rxapi.lib(rxReferencedModules.obj) : warning LNK4099: PDB '' was not found with 'rxapi.lib(rxReferencedModules.obj)' or at ''; linking object as if no debug info
4>rxapi.lib(nullSubent.obj) : warning LNK4099: PDB '' was not found with 'rxapi.lib(nullSubent.obj)' or at ''; linking object as if no debug info
4>rxapi.lib(libinit.obj) : warning LNK4099: PDB '' was not found with 'rxapi.lib(libinit.obj)' or at ''; linking object as if no debug info
4>test.obj : error LNK2032: metadata inconsistent with COFF symbol table: symbol '?isDerivedFrom@AcRxClass@@$$FSA_NPEBV1@0@Z' (0A0000E3) mapped to '<unknown symbol>' (0600024C) in test.obj
4>test.obj : warning LNK4248: unresolved typeref token (01000044) for 'AcDbStub'; image may not run
4>test.obj : error LNK2019: unresolved external symbol "public: static bool __cdecl AcRxClass::isDerivedFrom(class AcRxClass const *,class AcRxClass const *)" (?isDerivedFrom@AcRxClass@@$$FSA_NPEBV1@0@Z) referenced in function "public: bool __cdecl AcRxClass::isDerivedFrom(class AcRxClass const *)const " (?isDerivedFrom@AcRxClass@@$$FQEBA_NPEBV1@@Z)
4>StdAfx.obj : error LNK2001: unresolved external symbol "public: static bool __cdecl AcRxClass::isDerivedFrom(class AcRxClass const *,class AcRxClass const *)" (?isDerivedFrom@AcRxClass@@$$FSA_NPEBV1@0@Z)
4>Done building project "test.vcxproj" -- FAILED.
========== Build: 3 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
========== Build completed at 7:00 PM and took 21.685 seconds ==========
OysteinW
Hi!
The work-around for this problem for now is to use the static function AcRxClass::isDerivedFrom().
https://forums.autodesk.com/t5/objectarx/isderivedfrom-gives-a-linker-error-in-clr-projects-with-lat...
tbrammer
public: static bool __cdecl AcRxClass::isDerivedFrom(class AcRxClass const * __ptr64,class AcRxClass const * __ptr64)
is included in ac1st24.lib. Does it work if you add this lib explicitly in your projects Linker->Input settings?
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
OysteinW
Hi!
I tested this now on my project which is ObjectARX 2025 based, so I used ac1st25.lib, but it did not fix the issue.
It works fine in a pure C++ project without this library included, it's when enabling CLR on the project, the problem occurs.
moogalm
Autodesk Support
Autodesk Support
This is a bug with Visual Studio compiler, please use the static API instead, I have mentioned the workaround in bug report
OysteinW
No, the static function is the work-around. -as you suggested here:
https://developercommunity.visualstudio.com/t/After-a-VS2022-update-I-got-LNK2032:-The/10796640#T-N1...
turns out setting the project build properties to these fixed my issue:
Project -> Properties -> Configuration Properties -> General
Platform tools to
142
And windows SDK to
10.0.26100.0
