Dynamic Properties true color combobox
BerndCuder8196
Message 1 of 18
BerndCuder8196
does anybody know how to implement an color selection in OPM for true color?
Normally i implement it like this:
//IDynamicProperty
STDMETHODIMP Chtextcolor::GetCurrentValueName( /*[out]*/BSTR* pBstrName)
    *pBstrName = ::SysAllocString(L"ACAD_COLOR");
    return S_OK;
But this will only shows the color combobox for AutoCAD ACI, not for true color.
THanks, Bernd
Replies (17)
Message 2 of 18
Alexander.Rivilis
What wrong?
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 18
BerndCuder8196
Hello Alexander,
thanks for your reply.
For the entitys color property this is ok, but my custom entity have 2 AcCmColor i have implement in OPM via IDynamicProperty.
I use IDynamicProperty::GetCurrentValueName with ACAD_COLOR to show the standard AutoCAD color combo box.
But this shows only the combobox for Index Color (like CAcUiColorComboBox for dialogs), not with the tabs for True Color and Color Books (like CAcUiTrueColorComboBox for dialogs).
Message 4 of 18
Alexander.Rivilis
Why you implement this property via IDynamicProperty?
It is easy implement as static property:
STDMETHOD(get_MyColor)(/*[out, retval]*/ ACAD_COLOR* pVal);
STDMETHOD(put_MyColor)(/*[in]*/ ACAD_COLOR newVal);
Expert Elite Member
Message 5 of 18
BerndCuder8196
Thanks for your reply.
Unfortunally i need insert add. propertys in OPM also for AutoCAD Objects, but i think this will not work witch static property or can i register this for example an AcDbDimension?
By the way, i want test static property for my custom entitys, but when i create with objectarx wizard and Use ObjectARX ATL Extensions for custom entitys then there are 2 files missing and not created (MyProject.h and MayProject_i.c). What im doing wrong?
And is there no way to implement truecolor combobox in OPM via dynamic properties, olny ACI combo?
thanks Bernd
Message 6 of 18
BerndCuder8196
OK, i was able to create a COM Wrapper and implement it for my custom entity.
For true color combobox you need to implement as
STDMETHODIMP get_koteColor(IAcadAcCmColor **pVal);
STDMETHODIMP put_koteColor(IAcadAcCmColor *newVal);
and not
thanks, Bernd
Message 7 of 18
Alexander.Rivilis
IMHO with dynamic property you can not get combobox with true color but can use button with dialog in which you can use acedSetColorDialogTrueColor for selecting truecolor.
Expert Elite Member
Message 8 of 18
BerndCuder8196
Hi Alexander,
This was my first idea, an text box with the color name (ByLayer, 135, or RGB value) and an button for the true color dialog.
I think it is also possible to add an custom combo (derived from AutoCAD color combo) but my knowledge for this are to poor.
Message 9 of 18
Alexander.Rivilis
Sorry but it is impossible to derive from AutoCAD color combo. Also I can not found any possibility to create own-drawn button as dynamic property.
Expert Elite Member
Message 10 of 18
BerndCuder8196
Ok, I have found a funny thing in AutoCAD.
AutoCAD itself didn't show the true color combo for nested colors in OPM.
You can create an dimension style with true color for text and lines and then create an dimension with this true colors.
But in OPM these colors broken down to ACI and you can only change to another ACI color, not to an true color. Maybe they have forgotten to implement it. 🙂
@Anonymous, in Dynamic Property i was able to show the color name in OPM as text and add an ellipse button that calls the AutoCAD true color dialog. Only the color itself is not visible, but this is more than users can do with e.g. dimension text color 🙂
Message 11 of 18
Alexander.Rivilis
Yes. I was referring to this method and the impossibility of show a color icon picture in dynamic property.
Expert Elite Member
Message 12 of 18
i remember using something like this in the wrapper, for a complex object in my c++/arx days many moons ago:
in the .h
	STDMETHOD(get_ColorHatch)(/*[out, retval]*/ VARIANT *pv);
	STDMETHOD(put_ColorHatch)(/*[in]*/ VARIANT var);
in the .cpp
STDMETHODIMP CClosedPolygonWrapper::put_ColorHatch(VARIANT var)
	static AcGsColor AcadColors [] =
		{255, 255, 255, 255},  //----- 0 - ByBlock - White
		{255, 0, 0, 255},      //----- 1 - Red
		{255, 255, 0, 255},    //----- 2 - Yellow
		{0, 255, 0, 255},      //----- 3 - Green
		{0, 255, 255, 255},    //----- 4 - Cyan
		{0, 0, 255, 255},      //----- 5 - Blue
		{255, 0, 255, 255},    //----- 6 - Magenta
		{255, 255, 255, 255},  //----- 7 - White
		{128, 128, 128, 255},  //----- 8
		{192, 192, 192, 255},  //----- 9
		{255, 0, 0, 255},      //----- 10
		{255, 127, 127, 255},  //----- 11
		{204, 0, 0, 255},      //----- 12
		{204, 102, 102, 255},  //----- 13
		{153, 0, 0, 255},      //----- 14
		{153, 73, 73, 255},    //----- 15
		{127, 0, 0, 255},      //----- 16
		{127, 63, 63, 255},    //----- 17
		{76, 0, 0, 255},       //----- 18
		{76, 38, 38, 255},     //----- 19
		{255, 63, 0, 255},     //----- 20
		{255, 159, 127, 255},  //----- 21
		{204, 51, 0, 255},     //----- 22
		{204, 127, 102, 255},  //----- 23
		{153, 38, 0, 255},     //----- 24
		{153, 95, 76, 255},    //----- 25
		{127, 31, 0, 255},     //----- 26
		{127, 79, 63, 255},    //----- 27
		{76, 19, 0, 255},      //----- 28
		{76, 47, 38, 255},     //----- 29
		{255, 127, 0, 255},    //----- 30
		{255, 191, 127, 255},  //----- 31
		{204, 102, 0, 255},    //----- 32
		{204, 153, 102, 255},  //----- 33
		{153, 76, 0, 255},     //----- 34
		{153, 114, 76, 255},   //----- 35
		{127, 63, 0, 255},     //----- 36
		{127, 95, 63, 255},    //----- 37
		{76, 38, 0, 255},      //----- 38
		{76, 57, 38, 255},     //----- 39
		{255, 191, 0, 255},    //----- 40
		{255, 223, 127, 255},  //----- 41
		{204, 153, 0, 255},    //----- 42
		{204, 178, 102, 255},  //----- 43
		{153, 114, 0, 255},    //----- 44
		{153, 133, 76, 255},   //----- 45
		{127, 95, 0, 255},     //----- 46
		{127, 111, 63, 255},   //----- 47
		{76, 57, 0, 255},      //----- 48
		{76, 66, 38, 255},     //----- 49
		{255, 255, 0, 255},    //----- 50
		{255, 255, 127, 255},  //----- 51
		{204, 204, 0, 255},    //----- 52
		{204, 204, 102, 255},  //----- 53
		{153, 153, 0, 255},    //----- 54
		{153, 153, 76, 255},   //----- 55
		{127, 127, 0, 255},    //----- 56
		{127, 127, 63, 255},   //----- 57
		{76, 76, 0, 255},      //----- 58
		{76, 76, 38, 255},     //----- 59
		{191, 255, 0, 255},    //----- 60
		{223, 255, 127, 255},  //----- 61
		{153, 204, 0, 255},    //----- 62
		{178, 204, 102, 255},  //----- 63
		{114, 153, 0, 255},    //----- 64
		{133, 153, 76, 255},   //----- 65
		{95, 127, 0, 255},     //----- 66
		{111, 127, 63, 255},   //----- 67
		{57, 76, 0, 255},      //----- 68
		{66, 76, 38, 255},     //----- 69
		{127, 255, 0, 255},    //----- 70
		{191, 255, 127, 255},  //----- 71
		{102, 204, 0, 255},    //----- 72
		{153, 204, 102, 255},  //----- 73
		{76, 153, 0, 255},     //----- 74
		{114, 153, 76, 255},   //----- 75
		{63, 127, 0, 255},     //----- 76
		{95, 127, 63, 255},    //----- 77
		{38, 76, 0, 255},      //----- 78
		{57, 76, 38, 255},     //----- 79
		{63, 255, 0, 255},     //----- 80
		{159, 255, 127, 255},  //----- 81
		{51, 204, 0, 255},     //----- 82
		{127, 204, 102, 255},  //----- 83
		{38, 153, 0, 255},     //----- 84
		{95, 153, 76, 255},    //----- 85
		{31, 127, 0, 255},     //----- 86
		{79, 127, 63, 255},    //----- 87
		{19, 76, 0, 255},      //----- 88
		{47, 76, 38, 255},     //----- 89
		{0, 255, 0, 255},      //----- 90
		{127, 255, 127, 255},  //----- 91
		{0, 204, 0, 255},      //----- 92
		{102, 204, 102, 255},  //----- 93
		{0, 153, 0, 255},      //----- 94
		{76, 153, 76, 255},    //----- 95
		{0, 127, 0, 255},      //----- 96
		{63, 127, 63, 255},    //----- 97
		{0, 76, 0, 255},       //----- 98
		{38, 76, 38, 255},     //----- 99
		{0, 255, 63, 255},     //----- 100
		{127, 255, 159, 255},  //----- 101
		{0, 204, 51, 255},     //----- 102
		{102, 204, 127, 255},  //----- 103
		{0, 153, 38, 255},     //----- 104
		{76, 153, 95, 255},    //----- 105
		{0, 127, 31, 255},     //----- 106
		{63, 127, 79, 255},    //----- 107
		{0, 76, 19, 255},      //----- 108
		{38, 76, 47, 255},     //----- 109
		{0, 255, 127, 255},    //----- 110
		{127, 255, 191, 255},  //----- 111
		{0, 204, 102, 255},    //----- 112
		{102, 204, 153, 255},  //----- 113
		{0, 153, 76, 255},     //----- 114
		{76, 153, 114, 255},   //----- 115
		{0, 127, 63, 255},     //----- 116
		{63, 127, 95, 255},    //----- 117
		{0, 76, 38, 255},      //----- 118
		{38, 76, 57, 255},     //----- 119
		{0, 255, 191, 255},    //----- 120
		{127, 255, 223, 255},  //----- 121
		{0, 204, 153, 255},    //----- 122
		{102, 204, 178, 255},  //----- 123
		{0, 153, 114, 255},    //----- 124
		{76, 153, 133, 255},   //----- 125
		{0, 127, 95, 255},     //----- 126
		{63, 127, 111, 255},   //----- 127
		{0, 76, 57, 255},      //----- 128
		{38, 76, 66, 255},     //----- 129
		{0, 255, 255, 255},    //----- 130
		{127, 255, 255, 255},  //----- 131
		{0, 204, 204, 255},    //----- 132
		{102, 204, 204, 255},  //----- 133
		{0, 153, 153, 255},    //----- 134
		{76, 153, 153, 255},   //----- 135
		{0, 127, 127, 255},    //----- 136
		{63, 127, 127, 255},   //----- 137
		{0, 76, 76, 255},      //----- 138
		{38, 76, 76, 255},     //----- 139
		{0, 191, 255, 255},    //----- 140
		{127, 223, 255, 255},  //----- 141
		{0, 153, 204, 255},    //----- 142
		{102, 178, 204, 255},  //----- 143
		{0, 114, 153, 255},    //----- 144
		{76, 133, 153, 255},   //----- 145
		{0, 95, 127, 255},     //----- 146
		{63, 111, 127, 255},   //----- 147
		{0, 57, 76, 255},      //----- 148
		{38, 66, 76, 255},     //----- 149
		{0, 127, 255, 255},    //----- 150
		{127, 191, 255, 255},  //----- 151
		{0, 102, 204, 255},    //----- 152
		{102, 153, 204, 255},  //----- 153
		{0, 76, 153, 255},     //----- 154
		{76, 114, 153, 255},   //----- 155
		{0, 63, 127, 255},     //----- 156
		{63, 95, 127, 255},    //----- 157
		{0, 38, 76, 255},      //----- 158
		{38, 57, 76, 255},     //----- 159
		{0, 63, 255, 255},     //----- 160
		{127, 159, 255, 255},  //----- 161
		{0, 51, 204, 255},     //----- 162
		{102, 127, 204, 255},  //----- 163
		{0, 38, 153, 255},     //----- 164
		{76, 95, 153, 255},    //----- 165
		{0, 31, 127, 255},     //----- 166
		{63, 79, 127, 255},    //----- 167
		{0, 19, 76, 255},      //----- 168
		{38, 47, 76, 255},     //----- 169
		{0, 0, 255, 255},      //----- 170
		{127, 127, 255, 255},  //----- 171
		{0, 0, 204, 255},      //----- 172
		{102, 102, 204, 255},  //----- 173
		{0, 0, 153, 255},      //----- 174
		{76, 76, 153, 255},    //----- 175
		{0, 0, 127, 255},      //----- 176
		{63, 63, 127, 255},    //----- 177
		{0, 0, 76, 255},       //----- 178
		{38, 38, 76, 255},     //----- 179
		{63, 0, 255, 255},     //----- 180
		{159, 127, 255, 255},  //----- 181
		{51, 0, 204, 255},     //----- 182
		{127, 102, 204, 255},  //----- 183
		{38, 0, 153, 255},     //----- 184
		{95, 76, 153, 255},    //----- 185
		{31, 0, 127, 255},     //----- 186
		{79, 63, 127, 255},    //----- 187
		{19, 0, 76, 255},      //----- 188
		{47, 38, 76, 255},     //----- 189
		{127, 0, 255, 255},    //----- 190
		{191, 127, 255, 255},  //----- 191
		{102, 0, 204, 255},    //----- 192
		{153, 102, 204, 255},  //----- 193
		{76, 0, 153, 255},     //----- 194
		{114, 76, 153, 255},   //----- 195
		{63, 0, 127, 255},     //----- 196
		{95, 63, 127, 255},    //----- 197
		{38, 0, 76, 255},      //----- 198
		{57, 38, 76, 255},     //----- 199
		{191, 0, 255, 255},    //----- 200
		{223, 127, 255, 255},  //----- 201
		{153, 0, 204, 255},    //----- 202
		{178, 102, 204, 255},  //----- 203
		{114, 0, 153, 255},    //----- 204
		{133, 76, 153, 255},   //----- 205
		{95, 0, 127, 255},     //----- 206
		{111, 63, 127, 255},   //----- 207
		{57, 0, 76, 255},      //----- 208
		{66, 38, 76, 255},     //----- 209
		{255, 0, 255, 255},    //----- 210
		{255, 127, 255, 255},  //----- 211
		{204, 0, 204, 255},    //----- 212
		{204, 102, 204, 255},  //----- 213
		{153, 0, 153, 255},    //----- 214
		{153, 76, 153, 255},   //----- 215
		{127, 0, 127, 255},    //----- 216
		{127, 63, 127, 255},   //----- 217
		{76, 0, 76, 255},      //----- 218
		{76, 38, 76, 255},     //----- 219
		{255, 0, 191, 255},    //----- 220
		{255, 127, 223, 255},  //----- 221
		{204, 0, 153, 255},    //----- 222
		{204, 102, 178, 255},  //----- 223
		{153, 0, 114, 255},    //----- 224
		{153, 76, 133, 255},   //----- 225
		{127, 0, 95, 255},     //----- 226
		{127, 63, 111, 255},   //----- 227
		{76, 0, 57, 255},      //----- 228
		{76, 38, 66, 255},     //----- 229
		{255, 0, 127, 255},    //----- 230
		{255, 127, 191, 255},  //----- 231
		{204, 0, 102, 255},    //----- 232
		{204, 102, 153, 255},  //----- 233
		{153, 0, 76, 255},     //----- 234
		{153, 76, 114, 255},   //----- 235
		{127, 0, 63, 255},     //----- 236
		{127, 63, 95, 255},    //----- 237
		{76, 0, 38, 255},      //----- 238
		{76, 38, 57, 255},     //----- 239
		{255, 0, 63, 255},     //----- 240
		{255, 127, 159, 255},  //----- 241
		{204, 0, 51, 255},     //----- 242
		{204, 102, 127, 255},  //----- 243
		{153, 0, 38, 255},     //----- 244
		{153, 76, 95, 255},    //----- 245
		{127, 0, 31, 255},     //----- 246
		{127, 63, 79, 255},    //----- 247
		{76, 0, 19, 255},      //----- 248
		{76, 38, 47, 255},     //----- 249
		{51, 51, 51, 255},     //----- 250
		{91, 91, 91, 255},     //----- 251
		{132, 132, 132, 255},  //----- 252
		{173, 173, 173, 255},  //----- 253
		{214, 214, 214, 255},  //----- 254
		{255, 255, 255, 255},  //----- 255
		{255, 255, 255, 255}  //----- ByLayer - White
	// To use the AcPexCtl ActiveX object to marshal true color,
	// you must pass an IAcadAcCmColor dispatch pointer through, wrapped
	// in a variant.
	AcAxDocLock docLock(m_objRef.objectId(), AcAxDocLock::kNormal);
	if(docLock.lockStatus() != Acad::eOk && docLock.lockStatus() != Acad::eNoDatabase)
		return E_ACCESSDENIED;
	AcAxObjectRefPtr<ClosedPolygon> obj(&m_objRef, AcDb::kForWrite);
	if (obj.openStatus() != Acad::eOk)
	CComQIPtr<IAcadAcCmColor> pColor;
	HRESULT hr = pColor.CoCreateInstance(CLSID_AcadAcCmColor);
	// Set the marshalling object
	pColor=var.pdispVal;
	AcCmEntityColor tbackcolor;
	long colorVal;
	pColor->get_EntityColor(&colorVal);
	tbackcolor.setColor(colorVal);
	// color is by index - convert it to AcCmEntityColor !
	if (tbackcolor.isByACI())
		//acutPrintf(_T("\nColor is by index. "));
		AcGsColor col;
		col = AcadColors[tbackcolor.colorIndex()];
		tbackcolor.setRGB(col.m_red, col.m_green, col.m_blue);
	obj->ColorHatch(tbackcolor);
	Fire_Notification(DISPID_COLORHATCH);
	return S_OK;
in the .idl
	[propget, id(2), helpstring("Returns the truecolor of the hatch object.")] HRESULT ColorHatch([out, retval] VARIANT* pv);
        [propput, id(2), helpstring("Returns the truecolor of the hatch object.")] HRESULT ColorHatch([in] VARIANT var);
hope that will help somehow...
Message 13 of 18
Alexander.Rivilis
@Anonymous
It will be helpful but not for dynamic property. 🙂
Expert Elite Member
Message 14 of 18
thank you Alexander!, i see, have been out of this for a long time now. i tried 🙂
Luis.-
Message 15 of 18
KIMHENGHOR98
I tried this yet it did not work.for my custom color property.
Message 16 of 18
KIMHENGHOR98
Would you share me a custom color property?
Message 17 of 18
BerndCuder8196
Here is an example for an custom entity (CCNCTextLine).
The color related functions are:
STDMETHODIMP get_textColor(IAcadAcCmColor **pVal);
STDMETHODIMP put_textColor(IAcadAcCmColor *newVal);
Kind regards, Bernd
Message 18 of 18
KIMHENGHOR98
I need dynamic property custom color😳
