dwgOutFields does not get called
06:48 PM
Hi!
I have encountered a strange situation:
First the short version:
When I create a dictionary for a DWG-file, the dwgOutFields method gets
called when trying to close this document and the dictionary gets saved
correctly. When I then reopen the DWG-file, dwgInFields gets called (so
far, so good) and I modify some values of the Dictionary. When I then
try to close the document, dwgOutFields does _NOT_ get called and the
new values won't be stored.
Now the longer description:
I want to save the following class to my DWG file:
|| class AX3000_DWGData : public AcDbObject
|| private:
|| int m_nDimension;
|| public:
|| ACRX_DECLARE_MEMBERS(AX3000_DWGData);
|| AX3000_DWGData(): m_nDimension(0) {};
|| AX3000_DWGData(const int& val): m_nDimension(val) {};
|| int Dimension() { return m_nDimension; };
|| void Dimension(int _) { m_nDimension = _; };
|| virtual Acad::ErrorStatus dwgInFields(AcDbDwgFiler*);
|| virtual Acad::ErrorStatus dwgOutFields(AcDbDwgFiler*) const;
|| virtual Acad::ErrorStatus dxfInFields(AcDbDxfFiler*);
|| virtual Acad::ErrorStatus dxfOutFields(AcDbDxfFiler*) const;
I used the sample dwgInFields and dwgOutFields functions, which
look like this:
|| Acad::ErrorStatus AX3000_DWGData::dwgInFields(AcDbDwgFiler* pFiler)
|| assertWriteEnabled();
|| AcDbObject::dwgInFields(pFiler);
|| if (pFiler->filerType() == AcDb::kWblockCloneFiler) {
|| AcDbHardPointerId id;
|| pFiler->readItem(&id);
|| pFiler->readItem(&m_nDimension);
|| return pFiler->filerStatus();
|| Acad::ErrorStatus AX3000_DWGData::dwgOutFields(AcDbDwgFiler* pFiler) const
|| assertReadEnabled();
|| AcDbObject::dwgOutFields(pFiler);
|| pFiler->writeHardPointerId((AcDbHardPointerId)ownerId());
|| pFiler->writeItem(m_nDimension);
I use the overloaded "Dimension()" of AX3000_DWGData to store and read
the property "m_nDimension" from AX3000_DWGData, which works fine -
during runtime.
Everytime I retreive the dictionary handle from anywhere in my
ARX-Application, I get the correct value of m_nDimension.
If one part of my application increases m_nDimension, another part of my
Application retreives the correct value for it (Note: I always reget the
dictionary from the NamedObjectsDictionary just to be sure).
When I load a DWG-file with a dictionary in it, AutoCAD calls the above
listed dwgInFields Method and correctly reads in the value for the
property "m_nDimension", but when I then change m_nDimension with my
application and want to close AutoCad, no saving is done. Even If I
manually hit the "SAVE"-Button in AutoCAD, it does not call my
dwgOutFields method, so the value for m_nDimension is not updated in the
database.
Do I have to set a "dirty"-bit or something else for this dictionary to
be written out to the DWG-file?
Maybe some addiontal useful information:
When I open a new drawing in AutoCAD, which does not contain my
dictionary, I add this dictionary to the dwg-file with the following
function:
|| bool CreateDictionary()
|| AcDbDictionary *pNamedobj;
|| AcDbObjectId objId1;
|| AcDbDictionary *pDict;
|| AcDbDatabase *pCurDwg = acdbHostApplicationServices()->workingDatabase();
|| pCurDwg ->getNamedObjectsDictionary(pNamedobj, AcDb::kForWrite);
|| if(pNamedobj->getAt("AX3000_DATA", (AcDbObject*&) pDict, AcDb::kForWrite) == Acad::eKeyNotFound)
|| pDict = new AcDbDictionary;
|| AcDbObjectId DictId;
|| if(pNamedobj ->setAt("AX3000_DATA", pDict, DictId) != eOk)
|| pNamedobj ->close();
|| return false;
|| pNamedobj->close();
|| if (pDict)
|| if(pDict ->has("AX3000_DWGData"))
|| pDict ->close();
|| return true;
|| /* Add one instance of the AX3000_DWGData class to the dictionary */
|| AX3000_DWGData *pObj1 = new AX3000_DWGData(1);
|| AcDbObjectId rId1;
|| ErrorStatus es;
|| if((es = pDict->setAt("AX3000_DWGData", pObj1, rId1)) != eOk)
|| acutPrintf("\n%s\n", acadErrorStatusText(es));
|| pObj1 ->close();
|| pDict ->close();
|| return false;;
|| pObj1 ->close();
|| pDict->close();
|| else
|| return false;
|| return true;
When I then try to close AutoCAD, my dwgOutFields method gets called and
the dictionary is correctly stored inside the dwg-file.
Thanks in Advance,
| .-. | CCNA Alexander Griesser | .''`. |
| /v\ \ Software Developer, EDV Software Service / : :' : |
| /( )\ | Bahnhofstr. 8, 9500 Villach | `. `' |
|| private:
|| int m_nDimension;
|| public:
look like this:
during runtime.
database.
function:
|| return false;
|| pNamedobj->close();
|| if (pDict)
|| pDict ->close();
|| return true;
|| AcDbObjectId rId1;
|| ErrorStatus es;
|| pObj1 ->close();
|| pDict ->close();
|| return false;;
|| pObj1 ->close();
|| pDict->close();
|| else
|| return false;
|| return true;
Thanks in Advance,
