Dimension Placement
Dimension Placement
Kyudos
Advisor Advisor
Dimension Placement
Kyudos
It's a long shot but....does anyone know the formula AutoCAD uses to position the text for an AcDbAlignedDimension?
It has the following characteristics:
  1.  It is positioned halfway along the line it is dimensioning, with a perpendicular offset.
  2.  From 0° to 180° it is to the left of the line (start -> end)
  3.  From 0° to -180° it is to the right of the line (start -> end)
  4.  The offset is visually constant, independent of the current zoom state.
I can see how to calculate the position (1, 2 and 3) using a perpendicular vector that can be negated based on the angle - but how is the offset done? I assumed it would be related to DIMSCALE - but maybe has some relation to the viewport size too, in order to stay visually the same size?
Kyudos
(I'm messing with jigs again, BTW!)
So some trial-and-error shows that the offset I want appears to be 50% of the dimscale value at a given zoom state.
I'm setting this when creating my dimension as it is passed to AcEdJig::dimData.
So my dimension replicates the default as long as I don't zoom in or out while my dimension is active. So what value should I be getting in my "dimension value update" function to keep this 'current'? It's not the DIMSCALE system variable.
Kyudos
Further empirical evidence:
The dimscale value passed to AcEdJig::dimData is a constant 5.2011% of the active viewport width (and/or 14.5158% or the active viewport height).
I'm not so keen on "magic numbers" - can anyone see the real relationship being used here? I can use this empirically determined value to do what I want, but I rather have some understanding as to where this number comes from.
ynapeu
I am not 100% sure, but i think you mean dimGap. That is the distance between dimensionline und the text.
Kyudos
Thanks, but that's not the distance I mean.
This is DIMGAP:
I'm after this distance...
As above, I've determined it experimentally with some "magic numbers" which is good enough for now, but ultimately is not totally satisfactory.
ynapeu
ok. Maybe you test with
distance = viewportheigth*(25.4)*2/3000
if you are in the metric world.
