Default VS2019 Exception Settings Prevent Debugging AutoCAD 2023
Kyudos
Advisor Advisor
Kyudos
Trying to debug my ARX in ACAD 2023 / VS2019 with the default VS exception settings leads to an access violation error in starting up acad.exe which prevents the debugger from starting (this is before it even gets to loading my ARX).
I can ignore access violation errors and everything proceeds, seemingly as normal. But globally ignoring access violations doesn't seem like the best aid to debugging?
Is this normal? What else should I / shouldn't I be doing?
Cheers.
daniel_cadext
How are you starting the debugger? I always start AutoCAD, then attach to process, then load my ARX module.
I don’t think I’ve ever seen an exception before On_kInitAppMsg
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Kyudos
I start debugging directly from VS (F5) using the debug command line to launch AutoCAD and load a profile (/P option) that autoloads my debug ARX. This has been working fine until I tried to make my 2023 build. As I say, if I ignore the access violation the ARX loads fine. It also loads fine if I "Start without debugging" or if I start AutoCAD and then APPLOAD my arx.
daniel_cadext
Are you getting the access violations, debugging without loading your module?
I’m always doing dumb stuff like putting something in On_kInitAppMsg that needs a document, or a working database
Kyudos
Yes - it seems related to starting AutoCAD from the debugger.
Exception details:
Exception thrown at 0x00007FFD86ACC439 in acad.exe: 0xC0000005: Access violation reading location 0x0000000000000000.
Stack:
00007ffd86acc439()
00007ffd86acc1b6()
00007ffd86ac9f32()
00007ffd86ac9063()
00007ffd86ac3099()
Acdbmgd.ni.dll!00007ffd931c612b()
Acdbmgd.ni.dll!00007ffd931c559f()
00007ffd8698d9c3()
I find I can F5 through it (twice) but it's still annoying.
project setting->C/C++->Runtime Library:multithead DLL (/MD)
Kyudos
Yeah, already using that...
