Debugging arx application for AutoCAD 2012 with VS2010
For context, I'm on Windows 7-32bit; Visual Studio 2008 SP1 and 2010 SP1 are both installed.
I modified the project file (.vcxproj) by adding
    <TargetFrameworkVersion>v3.5</TargetFrameworkVersion>:
 <PropertyGroup Label="Globals">
  </PropertyGroup>
inside the  <PropertyGroup Label="Globals"> node.
I switched Platform Toolset from v100 to v90.
Then I launched AutoCAD 2012, loaded my arx solution in VS2010 and from the Tools menu, Attach to Process… I tried to select Attach to Managed v3.5 but it does not exist! All I see is Managed (v2.0, v1.1, v1.0) code or Managed (v4.0) code.
Am I the only one having this much fun with debugging? After sifting the internet I found no similar issues.
I’d appreciate your advice!
owenwengerd
You'll be more likely to get help with managed debugging by posting in the .NET group:
http://forums.autodesk.com/t5/NET/bd-p/152
Owen Wengerd
ManuSoft
augusto.goncalves
