Custom entity osnap points doesn't work
Hello, how can i define custom snap points for my custom entity? I'm implementing the "subGetOsnapPoints" method but the snap points doesn't appears when the mouse is closer, here is the implementation:
Acad::ErrorStatus Bolanum::subGetOsnapPoints (
	AcDb::OsnapMode osnapMode,
	int gsSelectionMark,
	const AcGePoint3d &pickPoint,
	const AcGePoint3d &lastPoint,
	const AcGeMatrix3d &viewXform,
	AcGePoint3dArray &snapPoints,
	AcDbIntArray &geomIds) const
	assertReadEnabled () ;
	switch(osnapMode)
		case AcDb::kOsModeEnd :
				snapPoints.append(mLinePosition);
				snapPoints.append(getCircleBorderPoint());
			break;
	return Acad::eOk;
Am i missing or doing something wrong? My entity full source is in the attachments as a lisp file.
I'm using ObjectARX 2012 and VS 2010 SP1. My entity is a ARX not an DBX object.
Alexander.Rivilis
Declaration of subGetOsnapPoints is:
    virtual Acad::ErrorStatus   subGetOsnapPoints(
                                    Adesk::GsMarker     gsSelectionMark,
                                    const AcGePoint3d&  pickPoint,
                                    const AcGePoint3d&  lastPoint,
                                    const AcGeMatrix3d& viewXform,
                                    AcGePoint3dArray&   snapPoints,
                                    AcDbIntArray &   geomIds) const;
So you have to replace:
with
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Well, it worked. The function signature generated by the ArxWizard is wrong, even in the docs the signature is like this:
subGetOsnapPoints( AcDb::OsnapMode osnapMode,
const AcGePoint3d& pickPoint, const AcGePoint3d& lastPoint, const AcGeMatrix3d& viewXform, AcGePoint3dArray& snapPoints, AcDbIntArray& geomIds) const;
I'm sorry for the stupid question. Thank you Alexander Rivilis.
Alexander.Rivilis
Some years ago I've informed Autodesk DevHelp about this. Help was corrected in new version:
New version of ARXWizard also now corrected. You can change those files yourself:
C:\Program Files (x86)\Autodesk\ObjectARX Wizards for AutoCAD 2012\ArxWizCustomObject\Templates\1033\object.cpp
C:\Program Files (x86)\Autodesk\ObjectARX Wizards for AutoCAD 2012\ArxWizCustomObject\Templates\1033\object.h
Expert Elite Member
I'm gonna fix it, thanks for the tip.
