Custom block can't be dynamic
11:40 PM
I created a new class (PICBlock) inherited from AcDbBlockReference I also create a wrapper(MgPICBlock) to use it in .Net.
class PICBlock : public AcDbBlockReference
public:
ACRX_DECLARE_MEMBERS(PICBlock);
static void makeMembers(AcRxMemberCollectionBuilder& collectionBuilder, void* customData);
protected:
static Adesk::UInt32 kCurrentVersionNumber;
public:
PICBlock();
PICBlock(const AcGePoint3d& position, AcDbObjectId blockTableRec);
Acad::ErrorStatus dwgOutFields(AcDbDwgFiler* pFiler) const final;
Acad::ErrorStatus dwgInFields(AcDbDwgFiler* pFiler)final;
Acad::ErrorStatus dxfOutFields(AcDbDxfFiler* pFiler) const final;
Acad::ErrorStatus dxfInFields(AcDbDxfFiler* pFiler)final;
Acad::ErrorStatus subClose()override;
void setManagedWrapper(gcroot<Autodesk::PIC::MgPICBlock^> p);
private:
gcroot<Autodesk::PIC::MgPICBlock^> m_pManaged; // the managed wrapper pointer.
Adesk::UInt32 PICBlock::kCurrentVersionNumber = 1;
ACRX_DXF_DEFINE_MEMBERS_WITH_PROPERTIES(
PICBlock, AcDbBlockReference,
AcDb::kDHL_CURRENT, AcDb::kMReleaseCurrent,
AcDbProxyEntity::kNoOperation, PIC-BLOCK,
PICBLOCK
"|Product Desc: PIC-ACAD"
"|Company: So.Build"
"|WEB Address: www.sobuild.fr",
PICBlock::makeMembers
void PICBlock::makeMembers(
void* customData)
readFromResource("PIC_Attributs.xml", collectionBuilder);
PICBlock::PICBlock() : AcDbBlockReference()
PICBlock::PICBlock(const AcGePoint3d& position, AcDbObjectId blockTableRec) : AcDbBlockReference(position, blockTableRec)
Acad::ErrorStatus PICBlock::dwgOutFields(AcDbDwgFiler* pFiler) const
Acad::ErrorStatus retStat = AcDbBlockReference::dwgOutFields(pFiler);
if (retStat != Acad::eOk)
return retStat;
retStat = pFiler->writeUInt32(PICBlock::kCurrentVersionNumber);
return retStat;
Acad::ErrorStatus PICBlock::dwgInFields(AcDbDwgFiler* pFiler)
assertWriteEnabled();
Acad::ErrorStatus retStat = AcDbBlockReference::dwgInFields(pFiler);
return retStat;
Adesk::UInt32 uiVersion = 0;
retStat = pFiler->readUInt32(&uiVersion);
return retStat;
Acad::ErrorStatus PICBlock::dxfOutFields(AcDbDxfFiler* pFiler) const
Acad::ErrorStatus retStat = AcDbBlockReference::dxfOutFields(pFiler);
return retStat;
retStat = pFiler->writeUInt32(AcDb::kDxfInt32, PICBlock::kCurrentVersionNumber);
return retStat;
Acad::ErrorStatus PICBlock::dxfInFields(AcDbDxfFiler* pFiler)
Acad::ErrorStatus retStat = AcDbBlockReference::dxfInFields(pFiler);
return retStat;
resbuf data;
retStat = pFiler->readItem(&data);
if ((data.restype != AcDb::kDxfInt32) || (retStat != Acad::eOk))
return (retStat != Acad::eOk) ? retStat : Acad::eNotApplicable;
uiVersion = data.resval.rint;
return retStat;
Acad::ErrorStatus PICBlock::subClose()
Acad::ErrorStatus es;
if ((es = AcDbBlockReference::subClose()) != Acad::eOk)
return es;
if (isWriteEnabled() == Adesk::kTrue)
//You have to cast it back to the managed type to do a null check:
if (static_cast<Autodesk::PIC::MgPICBlock^>(m_pManaged) != nullptr)
// Call the method on the wrapper which will propagate to all managed
// listeners of this event...
m_pManaged->PICBlockModified(ToObjectId(objectId()));
return Acad::eOk;
void PICBlock::setManagedWrapper(gcroot<Autodesk::PIC::MgPICBlock^> p)
m_pManaged = p;
ACDB_REGISTER_OBJECT_ENTRY_AUTO(PICBlock)[Autodesk::AutoCAD::Runtime::Wrapper("PICBlock")]
public ref class MgPICBlock : public Autodesk::AutoCAD::DatabaseServices::BlockReference
public:
MgPICBlock();
MgPICBlock(Point3d position, Autodesk::AutoCAD::DatabaseServices::ObjectId blockTableRecord);
internal:
MgPICBlock(System::IntPtr unmanagedPointer, bool autoDelete);
// Here is the method which will consistently give us our unmanaged (AsdkSimpleSquare) object.
inline PICBlock* GetImpObj()
// UnmanagedObject() is a method of the AutoCAD managed wrappers which always
// gives us a way to access the underlying ObjectARX objects so we can use them
// within our C++ application freely.
return static_cast<PICBlock*>(UnmanagedObject.ToPointer());
public:
// Here are the methods defined to support exposure of our event.
event PICBlockModifiedHandler^ PICBlockModified
public:
void add(PICBlockModifiedHandler^);
void remove(PICBlockModifiedHandler^);
void raise(Autodesk::AutoCAD::DatabaseServices::ObjectId);
private:
// Here is our member delegate which represents the event for this object.
PICBlockModifiedHandler^ m_pPICBlockModifiedHandler;
MgPICBlock::MgPICBlock() : Autodesk::AutoCAD::DatabaseServices::BlockReference(System::IntPtr(new PICBlock()), true)
GetImpObj()->setManagedWrapper(this);
m_pPICBlockModifiedHandler = nullptr;
MgPICBlock::MgPICBlock(Point3d position, Autodesk::AutoCAD::DatabaseServices::ObjectId blockTableRecord) :
Autodesk::AutoCAD::DatabaseServices::BlockReference(System::IntPtr(new PICBlock(AcGePoint3d(position.X, position.Y, position.Z), AcDbObjectId((const AcDbStub*)blockTableRecord.OldIdPtr.ToInt64()))), true)
// constructor for the managed wrapper This form takes an already established unmanaged object
// and simply attaches this wrapper to it.
MgPICBlock::MgPICBlock(System::IntPtr unmanagedPointer, bool autoDelete)
: Autodesk::AutoCAD::DatabaseServices::BlockReference(unmanagedPointer, autoDelete)
}If I create a blockrefrence from a dynamic block it works BUT if I create a PICBloc with the same blockrecord
I loose the dynamic properties.
I create blockrefrence and MgPICBlock in the same way.
MgPICBlock picblock = new MgPICBlock(position, blockRecId); BlockReference blockref = new BlockReference (position, blockRecId);
What I'm doing wrong ?
thanks
