current dwg file name
waseefur.rahman
Message 1 of 9
waseefur.rahman
Can any one guide me how to get the current dwg file name in C++,
By using this below code I am getting the full path with file name,
const ACHAR *dwgfilename = curDoc()->fileName();
but I need only the file name.
Accepted solutions (3)
Replies (8)
Message 2 of 9
tbrammer
How about this:
TCHAR drive[_MAX_DRIVE+1], dir[_MAX_DIR+1], fname[_MAX_FNAME+_MAX_EXT+1], ext[_MAX_EXT+1];
errno_t err = _tsplitpath_s(curDoc()->fileName(), drive, dir, fname, ext);
_tcscat_s(fname, _MAX_FNAME+_MAX_EXT, ext);
Thomas Brammer ● Software Developer ● imos AG ● LinkedIn ●
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
Message 3 of 9
waseefur.rahman
That's great,
One more help I need,
After getting the file name,
I need to create a new path with that file name.
Then copy file to that new path,
I have tried with the code below, but it's not working
//source path
const ACHAR * dwgsourcepath = curDoc ()->filename ();
//File name
//Destination path
const chat *dwgdestinationpath = D:\\New folder + fname [_MAX_FNAME + _MAX_EXT + 1];
//copy file from source to destination
std::ifstream in(dwgsourcepath);
std::ifstream in(dwgdestinationpath);
out << in.rdbuf();
Message 4 of 9
tbrammer
I'm not an expert for std-streams. Don't know whether they work for binary data.
This should work:
TCHAR dwgdestinationpath[_MAX_PATH+1] = _T("D:\\New folder\\");
_tcscat_s(dwgdestinationpath, _MAX_PATH, fname);
BOOL bFailIfExists=FALSE; // set TRUE if you don't want to overwrite existing file
BOOL bCopySuccess = CopyFile(dwgsourcepath, dwgdestinationpath, bFailIfExists);
Message 5 of 9
waseefur.rahman
Great,
Many Thanks ,
one more help Please,
Since "dwgdestinationpath" we are creating from below,
TCHAR dwgdestinationpath[_MAX_PATH + 1] = _T("D:\\New folder\\");
But I am getting this Destination path from below
kt::CStr sOutput
Also attached the screen shot,
From the coding you provided it copies the dwg file to destination without extension (i.e) .dwg
I would be highly thankful for your help..
Thanks & Regards
Message 6 of 9
tbrammer
I don't understand what I see in your PNG Smiley Sad
I made the assumption that you use fname after the function call
which appended the extension to fname.
Message 7 of 9
waseefur.rahman
Actually I can't directly enter the path as ("D:\\New folder"), Since it's variable..
I am getting this path from const char* path,
What I Need is I need to add file name to this path.
Then use this path in copy command as below,
CopyFile(dwgsourcepath, path, bFailIfExists)
Hope you got it..
Message 8 of 9
tbrammer
From your PNG it looks as you want to take the directory from sOutput.str(). I can't see what type sOutput is. You wrote that you get the path as const char*. So you have to convert it to TCHAR*. The easiest way to do this is to use CString, because it's construtor works with both: char* or wchar*:
TCHAR dwgdestinationpath[_MAX_PATH + 1];
CString csPath(sOutput.str()), csBackslash(_T("\\"));
if (csPath.Right(1) != csBackslash) // append '\' if required
    csPath += csBackslash;
_tcscpy_s(dwgdestinationpath, _MAX_PATH, (LPCTSTR)csPath);
Or just use CString everywhere to make it more readable:
CString dwgdestinationpath(sOutput.str()), csBackslash(_T("\\"));
if (dwgdestinationpath.Right(1) != csBackslash) // append '\' if required
	dwgdestinationpath += csBackslash;
dwgdestinationpath += fname;
Message 9 of 9
waseefur.rahman
That's Great,
got the solution,
Highly Thankful for your Help..
