Create Thread in ObjectARX
Dear all,
I am trying to create a thread in an ObjectARX project. The function I used is
CreateThread(NULL, 0, (LPTHREAD_START_ROUTINE)ThreadFunc, NULL, 0, &dwThreadId).
After the creation, the thread ID and Handle are returned successfully. But the created thread has never run.
Can anyone tell me if there is any way to solve this problem?
Cheers,
Yang
Yang:
How are you determining that the thread hasn't executed? Are you trying
to create the thread from within your DllMain() function?
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
Hi Owen,
Thanks for your kindly reply. I attached the snippet of my
code. I have registered a command "watch" in the command stack to activate the watchDb() method.
After the CreateThread () method, I got a returned value for the thread ID and the handle.
However, nothing is printed out like the first operation (print the sentence ("Already in Thread")), which makes me believe that the thread is not run.
I also use a software (like Windows Task Manager) that is able to trace all the Processes and their Threads, but the ThreadFun thread is not in the list.
void watchDb ()
if (gpDbr == NULL) {
gpDbr = new AsdkDbReactor();
acdbHostApplicationServices()->workingDatabase()->addReactor(gpDbr);
DWORD dwThreadId=0;
if (CreateThread(NULL,
0, &dwThreadId) == NULL)
acutPrintf("NULL Thread\n");
return ;
acutPrintf("\nThread id = %d\n", dwThreadId);
void ThreadFunc () {
acutPrintf("Already in Thread\n");
Thanks a lot.
Yang
OysteinW
From objectARX doc:
"ObjectARX Does Not Support Multi-Threaded Programming
If you spawn multiple threads in your application, make sure that no more than one of the threads at a time invokes anything in the ObjectARX system."
From the MSDN docs for CreateThread(): "A thread in an executable that calls
the C run-time library (CRT) should use the _beginthread and _endthread
functions for thread management...".
Dan
wrote in message news:5250034@discussion.autodesk.com...
Hi Owen,
and the handle.
list.
void watchDb ()
DWORD dwThreadId=0;
0,
return ;
Thanks a lot.
Yang
Your acutPrintf() call is not a reliable way to check whether the thread
is executing, because ObjectARX API functions do not support asynchronous
reentrancy. Use something independent of AutoCAD (such OutputDebugString
under a debugger) to test whether your thread is executing. 🙂
Owen Wengerd
Yes, Owen, you are definitely right. I tried other approaches and found out that the created thread was running, but it could not print out anything on the AutoCAD screen using acutPrintf().
Thanks for all the replies to help me out.
Cheers,
Yang Message was edited by: zhengy
