"Jim Massengale" wrote in message
news:682D02901D92B674636BACE1F47064CD@in.WebX.maYIadrTaRb...
> Attached is a drawing that has a problem with the defined Block "test".
> The block was created on the fly using ADS/RX code. The code hasn't
changed
> since R13 but after we were informed that in R2004 there were problems
noted
> after running Audit. I started looking at all the previous CAD versions.
> In all cads R14 and newer the block explodes to the lines not the
polylines
> that it should. Only in R2004 does it start showing errors if Audit is
ran.
> I have been trying to recreate the issue via LISP and haven't had much
luck.
> Can anyone shed some light on this?
> Jim Massengale
> Eagle Point
> AC1014g7'XÉ!&3'Y65G.¾.
N(T,å^Aà_:MÏ{#ýÞ8©_|h¸Nm3_£¿UÐ.@[jF)CŤ@P#0-A*@Pª"Ad@ÔiA$É&
¦ffffrOÉ©TTTTs"òjfffffäþªªª?õAXØYö'P°[( Qm%? ?£>o~9¹É?0
'Eõ''U'Õ':"ËWÚñTA2Õàv¼U@Oµx¯D#-^kÅqËWÚñ\A2Õàv¼W¡?©©"*>8ö]|ÿ@
p,
> ¬Ú'°4É-+LKñA@'½&1+- "$
> ¦¦P0@D'@"D+^Àô+'ü°?®¡zÔvÀz7Ьsú +^Àô+'ü
> ×£p=
·??fffffc"@z7Ыsúª£#3Scsf"£µÕãÅ'u'¥'U'E'a¤^me2èÈ£0=0"àÜ!Ç
V f-G±'Ì ¡Ä¸Ä©øÅÀÜô_ç϶S=Àr^;G;V:?# 0Iu @_^M_ DFìý
$÷'òøw`.÷'Üø'Ô,ùwpØùwÿÿÿÿL÷'ÜMöw°'h.¬÷'EÐ÷'"ñw£ñwÿÿÿÿøëý¤÷'B÷'
^M_øëýLh."h.øëýÜ'L@d? @0!@ 11ÐL?@¤? @0! ÿM@ä? @0!
¢'NAd? @0!11¶U
> OA¤
> @0
> O?Aä
> @09YPB$? @0 "Â'¦5P?Bd?
@0!'!*!+!,!-!.!/!0!1!2!3!4!5!6!7!8!9!:!;!>PÀKiÀ EGPT_LCADÀ"¾&PÀK
À EGPT_LCAD_AI_POC_SYMBOLÀ"ïØ'PÀKá@
EGPT_LCAD_AI_HEAD_SYMBOLÀ"¶(PÀL!À
EGPT_LCAD_AI_VALVE_SYMBOLÀ"Âí*PÀLbÀ
EGPT_LCAD_AI_FITTING_SYMBOLÀ"'ö*PÀL¢À
EGPT_LCAD_AI_EMITTER_SYMBOLÀ">',PÀLãÀ
EGPT_LCAD_AI_EQUIPMENT_SYMBOLÀ"Úg'PÀM!@
EGPT_LCAD_AI_PUMP_SYMBOLÀ"9+*PÀMbÀ
EGPT_LCAD_AI_CONTROL_SYMBOLÀ"é+PÀM£@
'EGPT_LCAD_AI_BACKFLOW_SYMBOLÀ" Ô .PÀMäÀ
EGPT_LCAD_AI_WATER_METER_SYMBOLÀ"-(PÀN!À
EGPT_LCAD_LC_PLANT_SYMBOLÀ" z'PÀNa@
EGPT_LCAD_AI_EVAL_SYMBOLÀ"sT(PÀN¡À EGPT_LCAD_LD_PLANT_SYMBOLÀ"
> J`$PÀNïÀ EGPT_LCAD_AI_PIPE_LEGÀ"Ë5$PÀO/À
EGPT_LCAD_AI_WIRE_LEGÀ"5õ$PÀOoÀ EGPT_LCAD_AI_DRIP_LEGÀ"cÎQB¤?
@0!Fc
> Q?Bä
> @0ê,J?C"À BPÐQÑÔ"ÕTô4EôÔÄ"äU5E"ÄTÒã'2'L@P'?
TESTÀªA0P2NAABD2Oõ@CÀPbØ[UU0
> !è ^(H(?)"iW"B?P¦ø[%ÿ2"¼:-áPò
'§>ÍýU,`¢
¿x'A?RbH[`"(? zZ CÀQbØ[UU8 ¦
> !ø " ¨(È))ý*½"B?Q¦ø[%ÿ2"¼:-àTs¦U?V]ýU`¢'?À?!B?Qæø{
§åw1:÷ç»C=îýU,`¢'¯#B?R&ø[ ZZrÔÍ7à<,¥;ã¦.ýU,`¢?5¦'A?SâH[`.(?
ËÈCÀR¢Ø[UU8!F
> !ø ´ È)h)Æ*}ÙO*B?Ràè['ÝzÜÒǺwçrxóÜÎeüNL<¤k\DßÔ,^zZ÷)B?S
ø{.b-õz-äõ[~úNvüNL<¤k\DYÕ,`¢>÷!B?Sfø{%ÿ2"¼:-àTs¦U?V]ýU,`¢'fè#B?S¦ø
['×ÝruÿwäoxZ}ýU,`¢?J:'A?TâH[`"~(? fÊCÀT"Ø[UU8"
> !ø Ô ^*(*F*ýªB"B?Tfø[
ZZrÔÍ7à_.h×U=ýU`¢'?ÀÄ?#B?T¦ø[ÁBjb\çrxóÜÎeýU,`¢?OL'A?UâH[`f~(?
\t8CÀU"Ø[UU8"?
> !ø " ^*¨*Æ+ÝNFB?Udø['?ª;
Û·õU`¢'?ÁUo#B?U¦ø["Ü7Æ¥<ãZ<[Ój¬ÝýU,`¢?t'A?W¢H[`.(? <ÎQCÀV"Ø[UU8#
> !ø " è+(+¦,]"62B?Vbø[ ü<¾cz8·æ[s~L4éüVÕ z.·ÊY"""é×''õ`¢'?Á1¹)B?V
ø{'ÝzÜÒǺw磱?Õt.üNL<¤k\DYÕ,`¢`?!B?Væø{
~è.GÜ×çrxóÜÎeýU,`¢'n2!B?W&ø{Xg*>-å·3麴%ýU,`¢'Xâ#B?Wfø[ÁBjb\âõÏ
þo8ÅYýU,
> `¢?êY'A?X¢H[`.(? \}CÀWâØ[UU8#æ
> !ø ô ^,,&,Ý:z"B?X&ø[DmV?7÷á·ÖÝ ¦ÝýU`¢'?À
ÿ#B?Xfø[ÎÏAø-åH|º×jíýU,`¢?.ç'A?Y¢H[`f~(? x9¦CÀXâØ[UU8$f
> !ø "
^,^,¦-]Tü"B?Y&ø[éfÒVÖåÝ49äb¶ÝýU`¢'?Àð>#B?Yfø[RsÖ¤×à÷KðVvõýU,`¢?wE
'A?Z¢H[`f~(? ;HCÀYâØ[UU8$æ
> !ø " ^--&-Ý?þ"B?Z&ø[
> 'AY°õÔ÷áÆRùvÍýU`¢'?À'u#B?Zfø['a
> X{Zv÷æÈþ'mz?õýU,`¢§7'A?[¢H[`f~(? v:cCÀZâØ[UU8%f
> !ø "
^-^-¦.]>""B?[&ø[ËlûJÚ-æ¬:ÐܾýU`¢'?À[j#B?[fø['f/uïGswæqëÀñ[^ÍýU,`¢Y'
'A?\¢H[`f~(? }LCÀ[âØ[UU8%æ
> !ø " ^..&.ÝêË"B?\&ø[À±>{wâ1¥Ï'UÖMýU`¢'?Ào×#B?\fø[
Y6è5H{·æq2í -UýU,`¢?té'A?]¢H[`f~(? {}¤CÀ\âØ[UU8&f
> !ø " ^.^.¦/],â"B?]&ø[Û
ÊT{-à·ZDõýýU`¢'?À-f#B?]fø[Æ)ûþ[×á£@Q+¼öýU,`¢¥Ç'A?^¢H[`f~(?
[?}CÀ]âØ[UU8&æ
> !ø " ^//&/ÝVà"B?^&ø[zsY
> >s?àç-ºð]výU`¢'?ÀHê#B?^fø[g5¹í°Çä??¦ò³ÞýU,`¢?®'A?_¢H[`f~(?
>MCÀ^âØ[UU8'f
> !ø "
^/^/¦0]àM"B?_&ø[·îa-Qy7æ÷iÓ^.ÍýU`¢'?À¬#B?_fø[\³+by7⬱R"VåýU,`¢?£ó
'A?`¢H[`f~(? ytCÀ_âØ[UU8'æ
> !ø " ^00&0Ý1Ù"B?`&ø[ fRÂ!ú-ã,ñb}4.¥ýU`¢'?À3.#B?`fø[§Êå
ÛáäÅÿmÝ'¥ýU,`¢8v'A?a¢H[`f~(? [@mCÀ`âØ[UU((
> !ø "
^0^0¦1}l4"B?a&ø[RsÖ¤×åeÌHåÞÕýU`¢'?ÀâØ#B?afø[ÎcrN±gæÃ'Æ.ôZõýU,`¢?ðÙ
'A?bâH[`"(? 1«ÃCÀaâØ[UU((
> !ø " ¨11F1ýª*B?b ø[®
jëDÖâbCÎOçî¥üNL<¤k\DYÕ`¢'?ÀB!B?bfø{'R,Rº47ã¾îa9-ÎÕýU,`¢']¥#B?b¦ø[éfÒV
ÖàqÎ)6KzõýU,`¢ò'A?câH[`"(? V+)CÀc"Ø[UU((
> !ø ´
^1¨1Æ2}Þf"B?cfø[Ôe?Áb¶Çá¿`v2ÕýU`¢'?Àýn#B?c¦ø[?-×ÍÕgã'ý)ù¨VýýU,`¢¬
'A?dâH[`f~(? UE*CÀd"Ø[UU((
> !ø " ^2(2F2ýìÍ"B?dfø[
è,1¶Çç'?ïf"¾ÅýU`¢'?ÀCí#B?d¦ø[JÏA?>~GåÍú±tæíýU,`¢4^'A?eâH[`f~(?
DCÀe"Ø[UU((
> !ø "
^2¨2Æ3}¸2"B?efø[ÉRùGà/XÜ3~>½ýU`¢'?À£Ã#B?e¦ø[ª¥0Ùl'äÐbM;í6åýU,`¢£'
'A?fâH[`f~(? ÆÞCÀf"Ø[UU((
> !ø " ^3(3F3ýFÂ"B?ffø[ ZSL\êø§ç¹
Í"f>¥ýU`¢'?ÀË4#B?f¦ø[ìo¢Ê8zã9hsg<öÕýU,`¢+ 'A?gâH[`f~(?
zG÷CÀg"Ø[UU((
> !ø "
^3¨3Æ4}'"B?gfø[ -1þ,Ëùçà¼c@æýU`¢'?À¶R#B?g¦ø[·6ãs?ç'?ïf"¾ÅýU,`¢?Û¶
'A?hâH[`f~(? ÛCÀh"Ø[UU((
> !ø " ^4(4F5ô"B?hfø[
«A«V8á@ÔÀ-þ¦ÅýU`¢'?ÀÝ\#B?h¦ø[¾?7÷àqÎ)6KzõýU,`¢Ï{'A?j"H[`"(?
7ãCÀi"Ø[UU((
> !ø " ¨4¨4æ5½dK"B?ifø[® jëDÖâbCÎOçî¥ýU`¢'?Àsn!B?i¦ø{
«A«V8á@ÔÀ-þ¦ÅýU,`¢'û#B?iæø[>88zá"=7P4îÕýU,`¢['A?kbH[`"~(?
z¼rCÀjbØ[UU((
> !ø ´
¨5H5?6=°£"B?j¦ø[Y0´}®;7äÃ>ªÄ¶eýU`¢'?À9(!B?jæø{F'ònE{Wá£@Q+¼öýU,`¢'ã#B
?k&ø[?,Ï9[÷äòTîíäõÕýU,`¢¤g'A?lbH[`"(? [$¨CÀk¢Ø[UU((
> !ø ´ ^5è66½´"B?kæø[-Ç·~ú÷â-(kÔÍÆ}ýU`¢'?ÀLo#B?l&ø[
wæÒ®A9ñfýU,`¢?~\'A?mbH[`f~(? XCÀl¢Ø[UU((
> !ø "
^6h6?7}"Þ"B?læø['f/uïGswä¨áS,Ö.ýU`¢'?Àǧ#B?m&ø[Ë,Ø=^·à¬Þ«£½ýU,`¢c'A
?nâH[`"~(? øCÀm¢Ø[UU((
> !ø " È6è7F7ý6]2B?mâø['OdÑ[Çâ1¥Ï'UÖMüVÕ z.·ÊY"""é×''õ`¢'?Á²)B?n
ø{éfÒVÖäw1W>þ¥üNL<¤k\DYÕ,`¢oº!B?nfø{:'Ò
Zwä¨áS,Ö.ýU,`¢'\~#B?n¦ø[Ç®»×á|ÔàÅÙN5ýU,`¢?¿¨'A?oâH[`"~(?
;ùCÀo"Ø[UU((
> !ø Ô ^7¨7Æ8ýZ*B?o`ø[ T
9v"-§æ=öº,ø¾üNL<¤k\DYÕ`¢'?ÀºÊ#B?o¦ø[K'Ovà¶çà÷KðVvõýU,`¢Ù<'A?qâH[`.~(
? 6¶ CÀp"Ø[UU((
> !ø "!8(8Æ9}©s2B?pbø[
> '"®7äÅPy?!,?üVÕ z.·ÒY.µBg<ò§õ`¢'?Á$)B?p è{¥t6ÖGäòTîíäõÕüVÕ
z.·ÊßÖ',^}1B?pâø{'OdÑ[ÇàÂkcG¢MüVÕ z.·ÊY"""é×''õ,`¢'.)B?q
ø{Ôe?Áb¶Ççä"%
> `¢'²#B?q¦ø[
> åâ?>GávyàÆÈ'.ýU, `¢¤\'A?râH[`.~(? 5CÀr"Ø[UU((
> !ø!
^9(9F9ýr£"B?rfø[]Ïþû?æ³"ܾTýU`¢'?Àö^#B?r¦ø[<>;çæ¦ûÿ_°¥aýU,`¢?¼"
'A?sâH[`f~(? ;"ÈCÀs"Ø[UU((
> !ø " ^9¨9Æ:}?"B?sfø[
<ÐDãt[gçxä;½EÞ'ýU`¢'?Àź#B?s¦ø[ߤbº¡[ÇçönØw½ÎAýU,`¢]'A?tâH[`f~(?
[ÔâCÀt"Ø[UU((
> !ø " ^:(:F:ý¼°"B?tfø[?¹6lû§äe
EO©ýU`¢'?À«-#B?t¦ø[3°òt`üàKCö+µýU,`¢Ï['A?uâH[`f~(?
|UøCÀu"Ø[UU((
> !ø "
^:¨:Æ;éÇ"B?ufø[Ì»í¥J[Gç'RnOï5qýU`¢'?À@'#B?u¦ø[<>;çæ7â²][\.ýU,`¢??'
A?w"H[`"(? ;> CÀv"Ø[UU((
> !ø " ¨;(;f<5*B?v`ø['±[IZááò?ÁüNL<¤k\DYÕ`¢'?Á¡A!B?v¦ø{
> åâ?>GäCåz¢?µiýU,`¢'Té#B?væø[uO«»oçäÿH>KáýU,`¢>6'A?x"H[`"(?
p×CÀwbØ[UU((
> !ø ´ ^;È;æ<ÝkL"B?w¦ø[ f4ûãYA'ô?-ýU`¢'?À®*#B?wæø[-1P?{ÇáÊOlÞV
ýU,`¢?ók'A?y¢H[`"~(? {/CÀxbØ[UU((
> !ø " È<¦=]³"2B?x¢ø[~4é¶áBO"à¹üVÕ
z.·ÊY"""é×''õ`¢'?ÁÍ)B?xàø{ -dV¼$úã@N^X4UÁüNL<¤k\DYÕ,`¢µ !B?y&ø{
f4ûãYA'ô?-ýU,`¢'M#B?yfø[O)TÖ¯;?ãç¦OÚØvaýU,`¢dê'A?z¢H[`"~(?
;mZCÀyâØ[UU((
> !ø Ô ^==&=Ýñ."B?z&ø[=FoYúãÑ>FH|Þ¹ýU`¢'?ÀsS#B?zfø[
> cF"¬Ü:æ°0¤Ì¤áýU,`¢??j'A?{¢H[`f~(? :ZCÀzâØ[UU((
> !ø " ^=^=¦>]>À"B?{&ø[YGÓ;"ÚçåÝ'½·Z'ýU`¢'?Àµ:#B?{fø[ f4ûæ
!(lÌZ©ýU,`¢?'A?|¢H[`f~(? {o¼CÀ{âØ[UU((
> !ø "
^>>&>ÝkØ"B?|&ø['³û¾!gåðE^çõΡýU`¢'?Àøû#B?|fø[']W?<{gäOa5ÃQ&?ýU,`¢?°
> 'A?}¢H[`f~(? {]¼CÀ|âØ[UU((
> !ø " ^>^>¦?]Á°"B?}&ø[ 'Ë
> 4çz'ãÑ>FH|Þ¹ýU`¢'?À.#B?}fø[ã|ªu§æò?´¯^fÁýU,`¢?Fw'A?~¢H[`f~(?
ßU'CÀ}âØ[UU((
> !ø " ^??&@
GØ"B?~&ø[»--8'ÙÇã÷©®¶X~TýU`¢'?À'f#B?~fø[ÊX"SrGälýGÍFÙýU,`¢?t!'A??@"
^[`"~(? G|÷'CÀ~âØ[UU((
> !ø " È?^?æ@ .jÈ*B?
ø[?*¨ðí~gáVýî;fyüNL<¤k\DYÕ`¢'?Áî6!B?fø{fߢ(SyçåÉè¥fýU,`¢'8+!B?¦ø
{»--8'ÙÇåÝ'½·Z'ýU,`¢'¿ã#B?æø[ º/uÛZÇá g"ö¹ýU,`¢'÷'A??A"^[`"~(?
G½÷CÀ?@c[UU((
> !ø Ô ^@ H@ f@!û#B??@§8[´M)
Xã'ig<¿¦ÑýU`¢'?Á¹,$B??@ç8[ý,½T§ádDIzÆéýU,`¢ÃÇ'A??B"^[`f~(?
ÎCÀ?Ac[UU((
> !ø " ^@ È@ æ@!"+/#B??A§8[z¸?*W¸'âYjÛJ&áýU`¢'?ÀÛ
$B??Aç8[Ա˼"wçåþøÆpð×ýU,`¢o.'A??C"^[`f~(? wI"CÀ?Bc[UU((
> !ø " ^@!H@!f@"x»#B??B§8[?ZXÃßwãÑ>FH|Þ¹ýU`¢'?À"ó$B??Bç8[
ZSL\êø§äT)Z53ùýU,`¢? > !ø "
^@!È@!æ@#$Ó{#B??C§8[ßßDc3§å«f¨'6?éýU`¢'?À~e$B??Cç8['j&:
GÖGåþøÆpð×ýU,`¢?úý'A??Fb^[`?(? VGyCÀ?Dc[UU((
> !ø "!(@"H@#@#¤S83B??D£8[
> '"®7äÅPy?!,?üVÕ z.·ÒY.µBg<ò§õ`¢'?ÀÊO*B??Dá({'Êfù5çáBO"à¹üVÕ
z.·ÊßÖ',^}8?2B??E#8{ T
> 9v"-§ç'Þ³<ÖüVÕ
z.·ÊY"""é×''õ,`¢':q*B??Ea8{x|å+?gáÃ3éá?yüNL<¤k\DYÕ,`¢ìo"B??E§8{k2ñ
yWãÑ>FH|Þ¹ýU,
> `¢'Ü"B??Eç8{ßßDc3§ä3EßvéýU, `¢'5Û$B??F'8[¬-~è'§ãå9`N
> OýU,`¢ ·'A??Gb^[`?(? '?JCÀ?F£[UU((
> !ø!4 ^@#h@#?@$._#B??Fç8[Zo]?";àVMÊ´?ýU`¢'?Àì+$B??G'8[Û
ÊT{-áVýî;fyýU,`¢?"ÿ'A??Hb^[`f~(? {C CÀ?G£[UU((
> !ø " ^@#è@$@$¤fð#B??Gç8[§Êå
Ûæ¨'o¬«?ýU`¢'?À¢ó$B??H'8[ÍðwÉ«»wâò'r8ØÖ'ýU,`¢?£Ã'A??Ib^[`f~(?
;fPCÀ?H£[UU((
> !ø " ^@$h@$?@%$q.#B??Hç8['uA<ÚZwáÑcÞ
O-'ýU`¢'?À²H$B??I'8[1/Hæ¨'o¬«?ýU,`¢?A9'A??Jb^[`f~(?
Á?CÀ?I£[UU((
> !ø "
^@$è@%@%¤æÆ#B??Iç8[?ì{?.s÷àÇ.?'''¡ýU`¢'?À©$B??J'8[Ûý~{ûWåÝ'½·Z'ýU,`
¢?'N'A??Kb^[`f~(? {¡CÀ?J£[UU((
> !ø " ^@%h@%?@&$^'#B??Jç8[ Êb)¸×à"ßp1Þ¾¹ýU`¢'?ÀÂo$B??K'8[
> *¨cQ-ãp{ÆæÎùýU,`¢?8D'A??Lb^[`f~(? SCÀ?K£[UU((
> !ø " ^@%è@&@&¤fº#B??Kç8[Òô( uz7â+
> ÛA-ιýU`¢'?À"Þ$B??L'8[(ÿ"9HÚWåº~`W$VÙýU,`¢??)'A??Mb^[`f~(?
ZF»CÀ?L£[UU((
> !ø "
^@&h@&?@'$,×#B??Lç8[¼Sk¶Js׿¦ÿFÏ^©ýU`¢'?Àèt$B??M'8[ÊR^×Ú·åÉÒ,'.ÉýU,`
¢?â
> 'A??Nb^[`f~(? ZºCÀ?M£[UU((
> !ø " ^@&è@'@'¤?#B??Mç8[¼sZÃpZ·âÖü'FTýU`¢'?À$B??N'8[ÖÃMlIZ÷â+
> ÛA-ιýU,`¢?o5'A??Ob^[`f~(? ZĺCÀ?N£[UU((
> !ø " ^@'h@'?@(d>#B??Nç8[ Âýâs7àÓËT-
æ?ýU`¢'?À$B??O'8[Y0´}®;7á¼ÆÄ'ΩýU,`¢öy'A??Pâ^[`"~(?
;ÚCÀ?O£[UU((
> !ø "
È@'è@(F@)"-'+B??Oá8['"vßdø÷àz÷&ÊÎYüNL<¤k\DYÕ`¢'?Àð£"B??P'8{ië=>ÚàÖ`8
W?î?ýU,`¢'æ>"B??Pg8{
iËî:7àY¡_Óæ¹ýU,`¢'ûé$B??P§8[ÞS½Zswã'ig<¿¦ÑýU,`¢õû'A??S"^[`?(?
ÂÃ'CÀ?Q#[UU((
> !ø È@(¨@)f@)¢3B??Qc8[
> '"®7äÅPy?!,?üVÕ z.·ÒY.µBg<ò§õ`¢'?À½¯2B??Q£8{ ü<¾cz8·æ[s~L4éüVÕ
z.·ÊY"""é×''õ,`¢'}2B??Qã8{
> o¬d~Wà[E*-
üNL<¤k\DY-×aæ'"°'õ,`¢'¨®*B??R!({¨3vßdø÷âä¢÷&ÊÎYü_]?~r'ÀßÖ!,^|¿*B??Ra8
{ ü<¾cz8·àÓËT- æ?üNL<¤k\DYÕ,
> `¢'%ÿ"B??R§8{ Êb)¸×àY¡_Óæ¹ýU,
`¢'q<$B??Rç8[-Êy×å-àÙB+¶éýU,`¢Gu'A??Sb^[`"~(? yïª'A@?Sâ^[ (?
yA$!L@F«? *MODEL_SPACEÀªA0P1@@1'00A@G"H[(? L/f!L@Eë?
*PAPER_SPACEÀªA0P1@@1·DA@FbH[(? R,úLÀCæ 0ÀAÐ@OEê%M@D
STANDARDÂ`jffffg$ýtxt@̲%N@E ?
> CONTINUOUSÄ)M½±¥±¥¹-AA0PÓWN@E)?? BYBLOCKÊAA0PÊN@Ei??
BYLAYERÊAA0PËT"P@?p§Ð@ *ACTIVEÀùjiiiiI@ë¸'·
> .@v?£!r+@ª~I@¡ð?ð?,~PøúA,?"ÐPÀDg@ ACADÀ f îPÀJ©À
EGPT_EPODÀ"ö^PÀJé@ EGPT_ENDÀ"H¯PÀK-@ EGPT_NODE_LEADERÀ"
ñpQ@Gd0 STANDARDÃ??)A$ µèÜB±ÏÀ ñJàzG`ü
> ×£p=
> Ç?ªµèÜB±ÏÀz7Ыsøffffff9@d
> ×£p=
> ·?ªª .((^PÌJ?Ce?A 0²/'J?Cª BÕS'T'0@C DÀÞÕA?S£Ø[ S^ªj^(
> !èOR'AFå~[!.I©è^©<êj(h¦
> !èAs'AF%~[!.J*ªKêj(h¦
> !èRH?R@DìàSTANDARD¨-DTû!ù? Q>È~OÀ?üÿ8/óýÿ8Ã8GPB$? @0
"Ã1`"P@?pçÐ@ *ACTIVEÀùjiiiiI@ë¸'·
> .@v?£!r+@ª~I@¡ð?ð?,~PøúA,?'Ç'°ÜÜ@-'?Ô'®J
òÀH>ÄDø@Á oKÝ@Ù ´Kó
Ú@'ïØ@'*+,..0+./2,+,((÷"&%<&%ÿ@».-%´
Að&Ú@-'Ò@Z6-%%áA&Ú@-&Ú@-&Ú@-&Ú
@-&Ú@-&Ú@-&Ú@-&Ú@-&Ú@-&Ú@-.%?AÃ
&Ú@-&Ú@-&Ú@-&Ú@-&Ú@-&Ú@-&%ÿ@»&
%ÿ@»&Ú@-&Ú@-6-%¼Aø.â@z6-5-%zBÚ&Ú
@-&Ú@-&Ú@-&Ú@-.%?AÃ&Ú@-6-%¼Aø&Ú
@-&Ú@-&Ú@-&Ú@- &Û@~
.%%®Aë#'à@z#'à@z#'à@z#'à@z#7.6.&&ÎBO#'
à@z#'à@z#'à@z#'à@z#'à@z#'à@z#'à@z#'à@z
#'à@z#/&&´Aò"766..&ÝB.ê
ÔKø'ÃéåJЬºQm%Z&G2dÿÿÿÿÔ{!Î("Y¿S$@ '<ªs5?PÌL MaàX2@@B
~3?ÀÉó`ÔGAà '@ 00@PP``pp?? °°ÀÀàÐÞÿQ-å
Ê+"Þ1×l`@¬Û¿öíÃUþ%mÔ6((WÊ?D+_NZ7PÞ7üM(´ixKÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
ÿÿÿÿÿÿÿÿÿÿÿÿÿ3fTÌÿ333f3T3Ì3ÿ3f3fffTfÌfÿfT3TfTTTÌTÿTÌ3ÌfÌTÌÌÌÿÌÿ3ÿfÿTÿÌÿÿÿ333
f3T3Ì3ÿ333333f33T33Ì33ÿ33f33f3ff3Tf3Ìf3ÿf3T33T3fT3TT3ÌT3ÿT3Ì33Ì3fÌ3TÌ3ÌÌ3ÿÌ3
ÿ33ÿ3fÿ3Tÿ3Ìÿ3ÿÿ3f3fffTfÌfÿf3f33ff3fT3fÌ3fÿ3fff3fffffTffÌffÿffTf3TffTfTTfÌTf
ÿTfÌf3ÌffÌfTÌfÌÌfÿÌfÿf3ÿffÿfTÿfÌÿfÿÿfT3TfTTTÌTÿT3T33Tf3TT3TÌ3Tÿ3TfT3fTffTTfT
ÌfTÿfTTT3TTfTTTTTÌTTÿTTÌT3ÌTfÌTTÌTÌÌTÿÌTÿT3ÿTfÿTTÿTÌÿTÿÿTÌ3ÌfÌTÌÌÌÿÌ3Ì33Ìf3Ì
T3ÌÌ3Ìÿ3ÌfÌ3fÌffÌTfÌÌfÌÿfÌTÌ3TÌfTÌTTÌÌTÌÿTÌÌÌ3ÌÌfÌÌTÌÌÌÌÌÿÌÌÿÌ3ÿÌfÿÌTÿÌÌÿÌÿÿ
Ìÿ3ÿfÿTÿÌÿÿÿ3ÿ33ÿf3ÿT3ÿÌ3ÿÿ3ÿfÿ3fÿffÿTfÿÌfÿÿfÿTÿ3TÿfTÿTTÿÌTÿÿTÿÌÿ3ÌÿfÌÿTÌÿÌÌ
ÿÿÌÿÿÿ3ÿÿfÿÿTÿÿÌÿÿÿÿÿ(((555CCCPPP]]]kkkxxx???"""¡¡¡®®®»»»ÉÉÉÖÖÖäääñññÿÿÿÿ
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿàÚ'ø+É××b¨5Àb»ïÔ
