Coordinate systems problem
Hi guies,
I have a problem with coordinate systems. Here it is:
If you have a Block A and it contains a block B in it then how to convert the position of block B into the UCS that I am draing into. I have the position of block B in the coordinate system of the block A and the position of block A into the current UCS but I need it into the coordinate system I insert block A.
It is not difficult to do it with mathematics but I need it with the ObjectARX :-))))).
I think you must look at this
acdbUcs2Wcs(firstPoint, firstPoint,
false);
acdbWcs2Ucs(lastPoint, lastPoint, false);
and also at this
acdbWcs2Ecs(p1, p1, dNorm, false);
Bernd
PS: you can also read the UCS/ECS from an object
Hi
guies,
If you
A.
ObjectARX :-))))).
Thanks I have already tried it but I have 3 coordinate systems A, B and C. A is implemented in B and B is implemented in C. So I think that these functions you recommend are making transormation of the points only in the Coordinate System-Container.
I think I'll make up with a little bit more mathematics
Thanks anyway.
I found the decision. Transformation matrixes.
