Compile error for SimpleToolPalette.vcproj ARX2010
Using Visual Studio 2008 (VS9) Standard Edition.
I'm able to compile ArxDbg.arx and load in ACAD2010, but when compiling
ARX2010\samples\editor\SimpleToolPalette_dg\SimpleToolPalette.vcproj
I get:
1>------ Build started: Project: asdkSimpleToolPalette, Configuration: Debug Win32 ------
1>Compiling...
1>StdAfx.cpp
1>C:\Program Files\Microsoft Visual Studio 9.0\VC\atlmfc\include\AtlCom.h(431) : error C2146: syntax error : missing ';' before identifier 'rgclsidAllowed'
1>C:\Program Files\Microsoft Visual Studio 9.0\VC\atlmfc\include\AtlCom.h(431) : error C4430: missing type specifier - int assumed. Note: C++ does not support default-int
1>C:\Program Files\Microsoft Visual Studio 9.0\VC\atlmfc\include\AtlCom.h(6053) : error C2039: 'rgclsidAllowed' : is not a member of 'ATL::ATL_PROPMAP_ENTRY'
1> C:\Program Files\Microsoft Visual Studio 9.0\VC\atlmfc\include\AtlCom.h(422) : see declaration of 'ATL::ATL_PROPMAP_ENTRY'
1>C:\Program Files\Microsoft Visual Studio 9.0\VC\atlmfc\include\AtlCom.h(6053) : error C2660: 'ATL::CComVariant::ReadFromStream' : function does not take 4 arguments
1>Project : warning PRJ0018 : The following environment variables were not found:
1>$(GINC)
1>Build log was saved at "file://c:\Autodesk\SDK\ARX2010\samples\editor\SimpleToolPalette_dg\Debug\BuildLog.htm"
1>asdkSimpleToolPalette - 5 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
The migration doc does not specify which VS edition is required. Do I need at least the Professional edition?
John
pavanjella
Hi John,
Can you try installing the below ATL update from Microsoft and see if it fixes the errors you are seeing?
http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=294de390-3c94-49fb-a014-9a38...
Hope this helps.
Problem fixed. Thanks!
