command is being executed?
Message 1 of 10
When I save a doc, AutoCAD tells me that some command is being executed, and let me to cancel the save action by return or retry by inputting R.
How can I know which command is being executed? And how can I stop this command?
Replies (9)
Message 2 of 10
Alexander.Rivilis
What about check CMDNAMES system variable?
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 10
命令: CMDNAMES
CMDNAMES = "SETVAR" (只读)
命令:  CMDACTIVE
CMDACTIVE = 1 (只读)
this is the vals of the two system variable.
It's possible to stop it?
Message 4 of 10
It's able to execute any command, like LINE, CIRCLE and so on.
But it's not able to execute the command SAVE.
Message 5 of 10
Alexander.Rivilis
It sounds like you locked a document and didn't dispose of your documentlock when you'd finished.
Is it possible?
Expert Elite Member
Message 6 of 10
Alexander.Rivilis
"Command in progress" after save as
Expert Elite Member
Message 7 of 10
yes, it's very possible.
I'll check it.
Thank you!
Message 8 of 10
Alex, is there good method to search the webpage in the AutoDesk community for the questions?
You always find the better answer than me.
Message 9 of 10
Alexander.Rivilis
I am using ObjectARX more than 20 years and teaching it more than 10 years. So it is a experience and intuition. 🙂
Expert Elite Member
Message 10 of 10
Yes, keep studying and keep doing is very important.
And how do you think about the vitality of ObjectARX and AutoCAD?
