Command in MDI mode
Command in MDI mode
Command in MDI mode
How can I write an AutoCAD command which will open a drawing and add a
line to it and will close the drawing with saving the changes. Is there any
way tro do it?
satya
extern "C" AcRx::AppRetCode acrxEntryPoint(AcRx::AppMsgCode msg, void* pkt)
switch (msg) {
case AcRx::kInitAppMsg:
acrxDynamicLinker->unlockApplication(pkt);
acrxDynamicLinker->registerAppMDIAware(pkt); // This line insert please.
initApp();
break;
case AcRx::kUnloadAppMsg:
unloadApp();
break;
return AcRx::kRetOK;
"satya" wrote in message
news:08B5573B49FDD12A780FA43B2BDE5AFE@in.WebX.maYIadrTaRb...
> Hi,
any
> way tro do it?
> Thanks
> satya
 switch (msg)
size=3>acrxDynamicLinker->registerAppMDIAware(pkt);
  initApp();
  break;
 case
  unloadApp();
break;
> Hi,
and add a
Is there any
> way tro do it?
> Thanks
satya
My code contains that line and still the following
code does not work as expected.
The line does not get added to the new file but
instead it gets added to the already opened drawing where the command was
issued. Any suggestions?
 AcDbDatabase* pNewDb =
NULL;
 acdbHostApplicationServices()->workingDatabase()->wblock(pNewDb);
 pNewDb->saveAs("E:\\TEMP\\1.dwg");
 delete
pNewDb;
 IAcadApplication
app;
 IAcadDocuments docs;
 IAcadDocument doc;
 app.AttachDispatch(acedGetAcadWinApp()->GetIDispatch(TRUE));
 docs.AttachDispatch(app.GetDocuments());
 doc.AttachDispatch(docs.Open("E:\\TEMP\\1.dwg",
COleVariant((short) FALSE, VT_BOOL)));
 doc.Activate();
 acedCommand(RTSTR, "_LINE", RTSTR, "0,0,0", RTSTR, "10,10,0",
RTNONE);
 switch (msg)
  initApp();
break;
  unloadApp();
break;
> Hi,
drawing and add a
> way tro do it?
> satya
Hi. satya.
Can not know in detail about your program.
But,
there is contents that do not fit in form during code.
"10,10,0", RTSTR, "", RTNONE);
Is sorry because do not help.
Best Regards.
following code does not work as expected.
NULL;
 delete
pNewDb;
 IAcadApplication
app;
 IAcadDocument doc;
 doc.Activate();
RTNONE);
 switch (msg)
  initApp();
break;
  unloadApp();
break;
> Hi,
drawing and add a
> way tro do it?
> satya
satya,
You need a command running from the application context or call a function
from application context.
This will avoid the command to stop when the current document is changed due
a new file or an open file process.
Take a look at the following sample:
\ObjectARX 2002\samples\docman
(see acDocManager->executeInApplicationContext(); calls)
Also, be aware to treat zero document state as well.
Fernando.
> Hi,
any
> way tro do it?
> Thanks
> satya
WOW!!!!!!
It worked.
Thanks a TON.
"Fernando P. Malard" wrote in message
news:1492FAEDE8D4FBB81C3147653ED9C7DA@in.WebX.maYIadrTaRb...
> satya,
due
> Regards,
> Fernando.
> > Hi,
a
> any
> > way tro do it?
> > Thanks
> > satya
