Color syntax, dynamic help just for the ADN members?
I have VC++ . NET 2002 and the ObjectARX for Autocad 2005, I see on the
ARXwizard help, the section on inegrating objectarx help files into visual
studio . net and in the dynamic help section, the arx calls in color, is
that available only for ADN members?
And should I buy Visual Assist too?
Luis
For the color syntax... that is what I need...
LE.
Look back to Cyrille message 6/4/2004
15:10, and use the attached files on that mail and the web link files
Laurence
"Luis Esquivel" wrote in message
news:4839995@discussion.autodesk.com...
Luis
ADN membership has nothing to do with color syntax. This is a Visual
Studio option. For the enhancement of the Visual Studio editor you could
try Visual Assist, it does a great job (including better syntax color).
Thank you Laurence,
But for some reason I'm getting nothing on my OE search, do you have an
specific url link?
Luis.
Here is a copy of Cyrille's mail posted 6/4/2004, he also attached a file
which
I will attach but I think that the news group does not allow attachments
now, is so then send me a e-mail direct and I will forward the attachment on
to you
Laurence
Cyrille's original mail...
Please unregister the help and restart your IDE once more. Go into
Tools->Options->Environment->Help and choose the 'Visual Studio .NET
Combined Help Collection'. Then Ok and Close the IDE
When done download the ObjectARX 2005 HxS file from
http://adn.autodesk.com/liveupdate/Oarx2005Help.zip (posted here temporary
while the DevNote gets updated). Unzip the files anywhere you want, but I
recommend the 2005 Help folder. Then use the attached utility to register
the HxS on your system (change the version number to 2005). Restart the IDE.
After few minutes you should see the Visual Studio .NET Combined Help with
MSDN and ObjectARX 2005 (from the Table of Contents for exemple).
cheers
cyrille
news:4841255@discussion.autodesk.com...
Thank you Laurence,
specific url link?
Luis.
Thank you Laurence,
I'm testing Visual Assist, and it is pretty COOL!
Luis.
"Laurence Skoropinski" wrote in message
news:4841520@discussion.autodesk.com...
which
to you
Laurence
When done downl
