Closed curve question!
D_D_K
D_D_K
How do I get the derivative at the last point of a closed curve as this's illustration.
Is there a better way than finding the approximate point?
Thanks in advance!
tbrammer
In general you can use AcDbCurve::getFirstDeriv(double param, AcGeVector3d& firstDeriv) to calculate the derivative at the parameter param. This should also work for both start- and the end-parameter of a closed curve.
The bigger problem is to deal with "points of C1 discontinuity". I think the only safe way to find those points for general AcDbCurves is to retrieve the geometrically identical AcGeCurve3d with
AcDbCurve::getAcGeCurve (AcGeCurve3d*& pGeCurve, const AcGeTol& tol)
and use
Adesk::Boolean AcDbCurve::explode(
   AcGeVoidPointerArray& explodedCurves,
   AcGeIntArray& newExplodedCurves,
   const AcGeInterval* intrvl = NULL
) const;
to split it into C1-continuous curves and determine their derivatives at start/end-parameters.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
D_D_K
Thanks sir,
this is exactly what I needed. 🤠
