class-problem
class-problem
class-problem
hello,
I created a simple class "Test", with 2 member variables: an integer and
a double. When I want to get the information back from a class member,
the double value always turns out to be 0.
Does anyone know what I do wrong??
(when I do the same in a simple c++ program, it works fine...)
class Test
public:
Test() { iVal = 0; \
dVal = 0; }
Test(int newI, double newD) { iVal = newI; \
dVal = newD; }
~Test() {}
void setiVal (int newI) { iVal = newI; }
void setdVal (double newD) { dVal = newD; }
int getiVal () { return iVal; }
double getdVal () { return dVal; }
private:
int iVal;
double dVal;
void CreateAndReadTest()
Test NewTest(5, 5.8);
acutPrintf("\n *** New Test Parameters ***");
acutPrintf("\n - integer value: %i", ActiveTest.getiVal());
// gives the correct info
acutPrintf("\n - double value: %d", ActiveTest.getdVal());
// always gives zero...
return;
hold your light, Eleven
Jeroen,
acutPrintf("\n - double value: %2.4f", ActiveTest.getdVal());
or a whole range of format options the .4 is the number of decimal places.
You should also initialise dVal = 0.0;
Regards Gary,
"Jeroen Henckaerts" wrote in
message news:[email protected]...
> hello,
> class Test
> public:
> dVal = 0; }
> dVal = newD; }
> ~Test() {}
> private:
> int iVal;
> double dVal;
> return;
"Gary D'Arcy" wrote in
news:[email protected]:
Thanks a lot!
Where can I find these format options??
regards,
jeroen
> Jeroen,
> places.
> Regards Gary,
Jeroen,
In any C++ book or in the C++ help!
You can format the string prior to output using this option!
e.g.
sprintf("\n%-35s %s %10.2f", temp, comma, total);
Note the "-" for justification!
Have fun!
Gary
www.drcauto.com
> Thanks a lot!
> regards,
> jeroen
> > Jeroen,
> > places.
> > Regards Gary,
Thanks again. 🙂
in a program that's not arx I always use "cout", and so did my c++ course,
that's why I'm not familiar to these notations...
greetz,
jeroen
> Jeroen,
> e.g.
> Have fun!
> Gary
> www.drcauto.com
Even A C book will provide the info.
"Gary D'Arcy" wrote in message
> Jeroen,
> e.g.
> Have fun!
> Gary
> www.drcauto.com
> > Thanks a lot!
> > regards,
> > jeroen
> > > Jeroen,
> > > places.
> > > Regards Gary,
