Can't use dynamic UCS on Blocks
ynapeu
ynapeu
I canot use the dynamic ucs on blocks, is there a possibiltiy to do this?
If explode the block i can use the dynamic ucs.
deepak.a.s.nadig
Unfortunately, It is a limitation to use dynamic UCS on Blocks.
As a workaround, you can use AcDbNonSubEntDynamicUCSPE class(as AcDbDynamicUCSPE does not
work for blocks) and explode the block in getCandidatePlane to iterate through the objects.
