Can't add varable - got script error
I 'm trying to add a variable using the Autodesk Class Explorer - Add
Variable
I get a Runtime error saying:
Line: 214
Error: 'Bases.Count' is null or not an object.
The error occur in the file arxCommon.js
Any clue?
htht
Johannes
What is the base class of your class?
Owen Wengerd
President, ManuSoft ==> http://www.manusoft.com
VP Americas, CADLock, Inc. ==> http://www.cadlock.com
"Johannes P. Hansen" wrote in message
news:5634915@discussion.autodesk.com...
Variable
Line: 214
Any clue?
htht
Johannes
Hi Owen,
I am pretty new to ObjectARX, so I tried out lab 3 in "ObjectARX for
dummies"
http://arxdummies.blogspot.com/2005/05/lab-3-solved.html
and I got to the point where I have added the ShapeObject, and I was going
to add the variable m_d when I got the error.
Base class must be AcDbObject.
Kind regards
Johannes P. Hansen
"Owen Wengerd" wrote in message
news:5635195@discussion.autodesk.com...
Owen Wengerd
Variable
Line: 214
Any clue?
htht
Johannes
Johannes:
Offhand I'm not sure why it's failing. I'm not familiar with those labs,
but I suggest emailing the author or posting a comment at that site. 🙂
Owen Wengerd
Thanks Owen.
It's not just that lab. I have created projects from scratch on different
PC's, added an ObjectDBX custom object succesfully but when it comes to add
a member variable to the object same result - it fails.
Guess I have to add the member variables the good old way, doing it by hand.
Kind regards
Johannes P. Hansen
news:5635682@discussion.autodesk.com...
Johannes:
Owen Wengerd
You might try updating your ObjectARX wizard to see if that helps.
Otherwise, debug the offending javascript code yourself to see what is going
on. 🙂
Owen Wengerd
I have installed the ObjectARX 2008; but with no success.
The problem seems to be relatetd to something else than the ObjectARX.
The scrips error occure in the file: C:\Program Files\Autodesk\ObjectARX
Wizards for AutoCAD 2008\ArxWizCommon\arxCommon.js in the line 214. The
cls.Bases.Count doesn't seem to set correct.
Problem is that I don't know anything about the Wizard, so I can't figure
out where to look.
Thanks for Your continous support.
HTH
Johannes
"Owen Wengerd" skrev i en meddelelse
news:5636329@discussion.autodesk.com...
on. 🙂
Owen Wengerd
