call VB form from c++ arx??
Is there a way to call a VB form from my arx file written in C++ ? I would like to use visual basic to create the dialog boxes that my application uses instead of creating a dcl file.
Any help is appreciated.
If your VB DLL/EXE is an ActiveX server, just use it like any other COM
server. But if you're doing this from scratch, why not incoporate dialogs
into your ARX?
Good judgment comes from experience.
Experience comes from bad judgment.
http://www.acadx.com
"rthyen" wrote in message
news:f0a0a2d.-1@WebX.maYIadrTaRb...
I have a large arx application already written in c++. It builds dialog boxes using dcl files.
I am wanting to change to visual basic forms for the ease of customization / changing the forms. With the use of dcl files there is little means of easily customizing the dialog boxes.
You can build UI's in VB and expose them via ActiveX to
any language. However, handling ActiveX events in C++
is a bit of a pain, but certainly possible. I routinely
use Delphi for UIs in conjunction with ARX/C++ back
ends.
news:f0a0a2d.1@WebX.maYIadrTaRb...
can anyone give some more insight on how this is done....
maybe a sample of code with a call or somwhere to read up on this
Rob
Hi Why don't you use CDialog instead of DCL. Why DCL was exposed to Arx beats me since you can create better dialog boxes right with C++. If you want a book on how to do it, pick up any "Learn C++ in 24 days". It will explain exactly how to add C++ dialog boxes to your existing project. I hope this helps, Chad Wanless
