I can't test with Acad 2014 or older. The code below runs well on Acad 2022 with your sample DWG. Can you try it with your version?
Acad::ErrorStatus postToDb(AcDbEntity* ent, AcDbDatabase* pDB) {
AcDbObjectId IdModelSpace = acdbSymUtil()->blockModelSpaceId(pDB);
AcDbBlockTableRecord* model;
Acad::ErrorStatus es;
if ((es = acdbOpenObject(model, IdModelSpace, AcDb::kForWrite)) == Acad::eOk) {
es = model->appendAcDbEntity(ent);
model->close();
return es;
void cmdMyRegion()
ads_name ss, ename;
int stat = acedSSGet(NULL, NULL, NULL, NULL, ss);
if (RTNORM != stat)
return;
Adesk::Int32 nSSLength = 0;
acedSSLength(ss, &nSSLength);
AcDbVoidPtrArray curves, regions;
AcDbObjectId objId;
AcDbEntity* ent;
for (Adesk::Int32 i = 0; i < nSSLength; i++)
acedSSName(ss, i, ename);
es = acdbGetObjectId(objId, ename);
if (!es) {
if ((es = acdbOpenObject(ent, objId, AcDb::kForRead)) == Acad::eOk) {
curves.append(ent);
ent->close();
acedSSFree(ss);
// close the curves
for (int i = 0; i < curves.length(); ++i) {
ent = static_cast<AcDbEntity*>(curves[i]);
ent->close();
es = AcDbRegion::createFromCurves(curves, regions); // create region(s)
if (!es) { // append region(s) to the modelspace
for (int i = 0; i < regions.length(); ++i) {
ent = static_cast<AcDbEntity*>(regions[i]);
postToDb(ent, acdbHostApplicationServices()->workingDatabase());
ent->close();
Thomas Brammer ● Software Developer ● imos AG ● LinkedIn ●
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
