C# Sortents
C# Sortents
Message 1 of 12
C# Sortents
I am new to C# and am trying to access the sortents table.
Can anybody give me some help?
When I look in the help files (ObjectArx Referance) I see this:
Acad::ErrorStatus
getSortentsTable(
AcDbSortentsTable*& pSortents,
AcDb::OpenMode openMode,
bool createIfNecessary = false);
I can tell this is referance for C or C+ but how do I use this in C#?
Replies (11)
Message 2 of 12
The BlockTableRecord has a DrawOrderTableId property
that is the ObjectId of the associated DrawOrderTable
managed wrapper class.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2004/2005/2006/2007
http://www.acadxtabs.com
wrote in message news:5196672@discussion.autodesk.com...
Acad::ErrorStatus
getSortentsTable(
Message 3 of 12
Thank for a nudge in the right direction!
Message 4 of 12
Ok, I am stuck again.
I am trying to get the DrawOrderTable and this is what I have done
DrawOrderTable dot;
Transaction trans;
trans=HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction();
dot=(DrawOrderTable)trans.GetObject(HostApplicationServices.WorkingDatabase.BlockTableId,OpenMode.ForWrite)
When I run this I get the following error:
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.InvalidCastException: Unable to cast object of type 'Autodesk.AutoCAD.DatabaseServices.BlockTable' to type 'Autodesk.AutoCAD.DatabaseServices.DrawOrderTable'.
What am I doing wrong?
Message 5 of 12
Look at your code.
You're trying to open a BlockTableRecord as
a DrawOrderTable.
wrote in message news:5198186@discussion.autodesk.com...
DrawOrderTable dot;
Transaction trans;
Message 6 of 12
Yes, I noticed that after I posted.
But when I get to
HostApplicationServices.WorkingDatabase.????
I do not get the choice to select DrawTable.
I guess I am asking is how to open the DrawOrderTable, I am sure its in the help files but I am having a tough time finding the info I need in them.
Message 7 of 12
Please review my first post in this thread,
note what object has the DrawOrderTableId
property.
wrote in message news:5199272@discussion.autodesk.com...
But when I get to
Message 8 of 12
Yep, I did that.
Thanks for the patients!
Anyone else who is following this extreemly painfull learning curve, heres what I did to get this to work.
Transaction trans=HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction();
DrawOrderTable dot;
BlockTableRecord btr;
btr=BlockTableRecord)trans.GetObject(HostApplicationServices.WorkingDatabase.CurrentSpaceId,OpenMode.ForWrite);
dot=(DrawOrderTable)trans.GetObject(btr.DrawOrderTableId,OpenMode.ForWrite);
Just like Tony said.
If this is still not tech correct please correct for the rest of us.
Thanks again
Message 9 of 12
Ok, More problems.
I have been trying for 2 day and I cant figure out what I am doing wrong.
I have a list of blocks names in a listview
I want to get the ObjectId's of the blocks
Then put them in a ObjectId Collection
Then pass the collection through the MoveToTop function(in the draworder table)
Heres what I did.
ObjectIdCollection Idcollection = new ObjectIdCollection();
//cycle throught the listview
foreach (ListViewItem item in lvwXrefs.Items)
//cycle through current space block record table
foreach(ObjectId objId in btr)
DBObject dbObj = trans.GetObject(objId,OpenMode.ForRead);
BlockReference blkRef = dbObj as BlockReference;
if (blkRef!=null)
BlockTableRecord blkDef=(BlockTableRecord)trans.GetObject(blkRef.BlockTableRecord,OpenMode.ForRead);
if (blkDef.Name == item.Text)
Idcollection.Add(blkDef.ObjectId);
dot.MoveToTop(Idcollection);
trans.Commit();
trans.Dispose();
Now I do get all the Object Id's and can print them to the editor.
But as soon as I try to pass them to the "movetotop" fuction, autocad crashs badly
any help?
Message 10 of 12
Your code appears to be adding the object ids
of block table records to the id collection, rather
than the ids of block references.
wrote in message news:5203828@discussion.autodesk.com...
Ok, More problems.
Heres what I did.
if (blkRef!=null)
trans.Commit();
trans.Dispose();
any help?
Message 11 of 12
As a somewhat related question,
Doesn’t the DrawOrderTable contain ObjectIds of block references?
As a last resort I tried taking the ObjectIds from the DrawOrderTable and putting them in the “MovetoTop” function and that also failed.
I guess I am really off the mark in terms of figuring out the logic of this. Message was edited by: Techno Destructo
Message 12 of 12
The DrawOrderTable contains the ids of any visible entity
(any object derived from AcDbEntity) which includes block
references.
Your code isn't adding block references to the DOT, it is
adding block definitions, which are not visible entities.
wrote in message news:5205008@discussion.autodesk.com...
I guess I am really of the mark in terms of figuring out the logic of this.
