AutoCAD 2019 porting problem
danipon71
danipon71
After the migration of an ARX project to AutoCAD 2019, I get the following compilation error:
error C2664: 'bool acedRemoveFilterWinMsg(const AcedFilterWinMsgFn)': cannot convert argument 1 from 'const AcedFilterWinMsgFn (__cdecl *)(MSG *)' to 'const AcedFilterWinMsgFn'.
I get that same error with the following methods:
acedRegisterFilterWinMsg ( const AcedFilterWinMsgFn pfn )
acedRemoveFilterWinMsg ( const AcedFilterWinMsgFn pfn )
acedRegisterWatchWinMsg ( const AcedFilterWinMsgFn pfn )
my hook function is declared like these:
const AcedFilterWinMsgFn MouseHook (MSG *pMsg)
what's wrong?
Thanks in advance
thierry_prince
A change in 2019 is that the callback function must now return a 'bool' and not a 'BOOL / int' as previous versions.
But if you use the typedef for AcedFilterWinMsgFn, it should be correct.
Try to remove the 'const' statement at the beginning of the function implementation :
Cheers,
Thierry
danipon71
Thanks a lot for your fast reply!
