Autocad 2016 for MAC - read dynamic block properties
I'm trying to read the dynamic block properties of a dynamic block.
I'm sure the block is a dynamic block, but the helper methods tell me it's not: (I have verified this with MdgDbg on Windows)
ads_name ssname;
    acedSSGet(NULL, NULL, NULL, NULL, ssname);
    Adesk::Int32 length = 0;
    acedSSLength(ssname, &length);
    ads_name ent;
    AcDbObjectId id = AcDbObjectId::kNull;
    for (long i = 0; i < length; i++) {
        if (acedSSName(ssname, i, ent) != RTNORM) continue;
        if (acdbGetObjectId(id, ent) != Acad::eOk) continue;
        AcDbEntity* pEnt = NULL;
        if (acdbOpenAcDbEntity(pEnt, id, AcDb::kForWrite) != Acad::eOk) continue;
        AcDbBlockReference* block = AcDbBlockReference::cast(pEnt);
        if (AcDbDynBlockReference::isDynamicBlock(id)) {
            acutPrintf(_T("\nID is dynamic block"));
        if (AcDbDynBlockReference::isDynamicBlock(block->objectId())) {
            acutPrintf(_T("\nObject ID is dynamic block"));
        if (AcDbDynBlockReference::isDynamicBlock(block->blockTableRecord())) {
            acutPrintf(_T("\nBlock Table Record is dynamic block"));
According to the docu I need to pass the blockTableRecord object id.
Does anyone have an idea what the issue could be?
BR
Another issue was, that I couldn't retrieve the block properties, this was solved just now:
if (acdbOpenAcDbEntity(pEnt, id, AcDb::kForRead) != Acad::eOk) continue;
makes this work at least.
So any idea why the check won't work?
tbrammer
I use this function to determine whether a block is dynamic. It takes the objectId of a BREF or a BTR to test:
bool isDynamicBlock(const AcDbObjectId &objId)
	AcDbObject	   *pObj;
	AcDbBlockReference *pBref;
	AcDbBlockTableRecord *pBTR;
	Acad::ErrorStatus es;
	AcDbObjectId blockTableRecordId;
	bool bIsBref=false,
	     bIsDynamic = false;
	// Is objId a BREF or a BTR?
	es = acdbOpenObject(pObj, objId, AcDb::kForRead);
	if (es==Acad::eOk)
		if (pBref = AcDbBlockReference::cast(pObj))
			blockTableRecordId = pBref->blockTableRecord();
			bIsBref = true;
			AcDbDynBlockReference dynBlockRef(pBref);
			// dynBlockRef.isDynamicBlock(); is not enough
			// It only returns true if the original source block is referenced!
			AcDbObjectId  dynBTRid = dynBlockRef.dynamicBlockTableRecord();
			if (!dynBTRid.isNull())
				bIsDynamic = AcDbDynBlockReference::isDynamicBlock(dynBTRid);
		else if (pBTR = AcDbBlockTableRecord::cast(pObj))
			blockTableRecordId = objId;
			bIsBref = false;
		pObj->close();
		if (!bIsDynamic)
			bIsDynamic = AcDbDynBlockReference::isDynamicBlock(blockTableRecordId);
	return bIsDynamic;
 I haven't tried it on a MAC. But it should work the same.
Thomas Brammer ● Software Developer ● imos AGLinkedIn
If an answer solves your problem please [ACCEPT SOLUTION]. Otherwise explain why not.
